Ok, so some progress on the Fuel Tank today. I had bent and cut most of it up last week. This weekend I decided to start doing some practice runs with the GTAW on some small pieces. I've been around welding my whole life, fairly proficient at GMAW, FCAW, and SMAW with Steel and Stainless, and GTAW steel and SS. However, the Aluminum was always my Fathers domain. His specialty, his craft. A true expert. In his heyday, his "Stack of Dimes" was more like Robotic. So when anything Aluminum came up, he would take care of it. I normally stuck to my own kind.... This is a bit different. Now I want to do it, and well he made it look so effortless, much the same as many of the better guys on Youtube. I know better than to think "How hard can it be?", but this is a WHOLE 'nother animal! I spent the better part of the weekend practicing grinding my Tungsten...Mind you, it's .080" aluminum, open corners, so it isn't a walk in the park for even some experienced Tig guys. Also, I'm using a Dinosaur Miller Synchrowave 300. Great machine for heavy Aluminum, but not as friendly with the thin stuff as the new inverter machines with pulse and frequency selection. I'd get a few good inches, then "Bam", either dip my tip, or blow a hole. Quite frustrating to say the least. Tonight, the little dim bulb at the back of the mind began to glow. Sometimes you have to step back, and have a GOOD look in the mirror. We TEACH welding and certify welders. I'm constantly telling guys "Make sure you are comfortable", "Do you need glasses, or a cheater lens", etc. I needed to follow my own advice. I realized I really couldn't see the puddle as well as I should even with a cheater. Time for a new cheater, or regular glasses again. Second, I broke out the "Clear View" technology Miller helmet I bought a while back but never put into use. Man, what a difference in the view of the puddle! So I went ahead and tacked up the sides of the tank, and dove in. They ain't going to win any beauty contest, but they are a great deal better than the Pidgeon Sh*t I was making over the weekend! Pretty good penetration overall, don't think there will be any problem with leaks. I also took a bit of time to set up the Power Mig 350 with .035" 4043, set for "Pulse on Pulse", and ran a couple of open corners. I'm impressed. Looked just like a Tig weld. Today I stepped outside of my comfort zone, and I grew a little. It was a good day!
_________________ Dismantalus, Fabricatus, Assemblus..... Certified Welder, Certified Welding Inspector, Full Time Car Freak...In New Jersey no less!
