Next up is the part of the project that has eaten up more hours than anything else: the fiberglass hood.
For those that are still paying attention at this point, you know that my donor drivetrain is taller than average, thus my decision to build my own nose cone/hood/scuttle, henceforth to be referred to simply as the "hood". I am not the first person to build a nose cone, and I hopefully will not be the last. This is my method that worked for me and in the beginning, I couldn't find any direct research to making a locost hood using this exact method and materials.
I used the 'mold-less' composite method to create the hood, meaning I didn't create a buck, then a female mold, then mold the actual hood from the female mold. I went directly from buck to fiberglass hood. This method has pros and cons, the biggest pro being the simplicity of the process.
I used polyester resin for this project. We can debate polyester vs epoxy ad-infinitum, but I chose polyester for the following reasons:
-polyester resin is less temperature and humidty sensitive (I did this during the winter)
-polyester resin is available at the local auto parts store (thats right, I used the bondo brand stuff by the gallon)
-polyester resin will not set up properly over epoxy, meaning the fiberglass resin jelly (bondo brand) and standard bondo filler would not work over epoxy (once again, low cost, local availability)
-polyester resin sets up quickly, meaning fewer runs on vertical surfaces
The buck was constructed of layers of 2" EPS (Expanded Polystyrene) foam from the local Menards. I stacked up enough layers around the engine and on the front of the chassis that I could carve out what I wanted. 3M makes a special spray adhesive for polystyrene, that works great. I used carpet tape to hold the foam to the chassis.
Unfortunately, I don't have any photos of the un-carved blocks, the spray adhesive is sticky and gets everywhere, so I chose not to handle my phone or camera.
For the bulk of the rough shaping, I used a sanding disc on my angle grinder. 24 or 36 grit is what you want, and don't be scared to make a mess, its unavoidable. You WILL need a respirator with eye protection. The small peices of foam become airborne and hang in the air, getting into your eyes and clinging to anything moist in your nasal passages.
This is what I had after some rough shaping:
I didn't draw anything on the buck up until this point, I simply shaped based on how I thought it should look. I did use the top of the chassis as a reference point for the top of the grille opening, but otherwise it was simply let the foam fly.
If you have time to clean your shop, you don't have enough interesting projects to work on.
