This weekend has encompassed some tedious jobs but necessary ones. The brake reservoir is now mounted. The grille is finished after hours of welding, grinding, filing, sanding, and more of the above
The stanchions are made, and I sketched these in Solidworks originally to have cut on the waterjet, but then noticed I had a sheet of 0.080 aluminum that they fit on nicely. Essentially, I ended up cutting them out by hand and having to weld in some bars for mounting them.
I looked more at the cooling system and I lowered the heater core by making some new mounts.
The upper coolant hose will just not work so i will have to look at some other options. Possibly a hose with a tighter bend, rewelding the radiator, or hose kit from Spectre (
https://www.speedwaymotors.com/Spectre- ... 00302.html). Any ideas? The picture with the hose gives a perspective on how little room there is.
davew: I don't think I will be running into that issue now, as I will be mounting an additional fill neck in lieu of the water neck (the yellow arrow). So the highest point will be there now. The filler neck on the radiator would not be necessary anymore and that is why I though of cutting it off and taping a new thread into it to possibly burp the top of the radiator as there might be an air pocket.
Tundra 7: I didn't have a foot pedal but 1/16 rod and 3/32 tungsten worked out for me at 15-20 amps.
BostonWill: The engine hoist is not only there for show, its my metal brake as well!
Alex
