It is currently April 26, 2019, 5:45 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: October 30, 2017, 10:06 pm
Not a programmer, but still hoping I can get some use out of the book. The second looked like it would be useful given the frame pictured on the cover. :) But yeah, I know I already have fixed dimensions in the spindle geometry, but I'm confident I can compromise around any issues that come up. I mean so far, I'm pretty happy with it.
Cold day here, but I managed to finish up the control arms tonight:
PostPosted: November 9, 2017, 12:36 am
Few minor things arrived.. New front hubs, and pads/rotors all around.
Been fiddling quite a bit with the suspension and steering geometry. Found a good place to get a custom rack built, so I have been working on the steering geometry too. Not quite ready to start welding yet, but so far the numbers are encouraging. 5" of rack travel will get me a very nice turning circle (still need to decide on a steering ratio though). Getting 4 degrees of caster with plenty of adjustment plus/minus. With 1deg of static camber, I am getting the outside to be at 0* in a hard turn, and the inside wheel has 1-2* of -ve camber. I think I can live with that. Added a bit of anti-dive, but might put a little more. I also had to put the rack slightly back of the centerline between steering pickups on the spindles, but that has a nice side bonus of, amazingly, basically perfect ackerman. And essentially no bump steer. So if anyone asks, I meant to do that......
Next step is to decide on wheel rates and spec out some shocks!
PostPosted: November 9, 2017, 9:42 am
As light as your Seven will be you could easily reduce the anti-dive by half. Heavy sedans with soft springs and a heavy motor run that much anti-dive. Your typical Seven is sprang pretty stiff.
I'm running about 1.2* I would also kick up the caster, unless this is a track only car.
Most Seven's are set up with about 5/8 to 3/4" frame rake, which effectively reduces the caster.
Dave W
PostPosted: November 9, 2017, 4:15 pm
Hm, interesting. The book I linked above suggested the anti-dive angles should cross at the center of gravity. I thought that was excessive.. will do more research.
It will be a track-only car but I'm sure I can get more caster if need be. What's the reason for the frame rake? I hadn't factored that in at all.
PostPosted: November 10, 2017, 9:02 am
The frame rake is typically used to as a way of adjusting wt transfer on the rear.
Being a track car, I would suggest that you look at running RU1&2 tubes horizontally Vs at an angle. That way you can mount the pandard rod lower. i.e. a lower roll center.
Also for a track car you may want to look at increasing your ackermann.
Dave W
PostPosted: November 27, 2017, 11:32 pm
Good advice, thanks. RUs are already welded in and to be honest I really like the look, so I will leave it as one of the few concessions to style.
Had a rough day at work today so decided to test fit my axle. Strongarmed the thing in there on my own. So far so good, I think. The trailing arms will be level with the car at ride height, I just didn't have any wood the correct thickness.
You can also see how I figured out the panhard rod. The chassis-side mount will be on the opposite frame rail. Hopefully that LCA bolt stud doesn't hit the frame at full droop. Don't think it will, but need to check. If it does, I will put a hole through the panhard bracket so I can feed the bolt in through that side. It's fully boxed so I'd have no concerns. Also, I am just using standard nuts for test fits, don't want to wear out the nylocks.
Really hoping to start on the front suspension soon. Though I may focus on getting the engine mounted first, because then I can get a driveshaft and build a tunnel for it.
PostPosted: December 11, 2018, 2:39 pm
I suppose I should update this again. I have been working hard over the summer and even harder now that it's winter again. I decided to paint the chassis now because I won't be able to sandblast it later on in the winter, and most of the major welding was done. Where I need to add a small bracket here and there, it's easy enough to grind the paint away, weld, and touch it up later.
I kept the wheels and tires from my RX8 for the purposes of test fitting. They are 245/45 on 17x8 SN95 Mustang wheels. Not exactly the ideal size, but for the purposes of test fits and perhaps initial road testing, they should be okay.
I am currently working on the pedal box and mounting the fluid reservoirs. Once that's done, I will likely plumb in the brake lines, followed by the fuel lines, leaving electrical to the end.
https://drive.google.com/file/d/1n22YY9 ... sp=sharing
Ah, I see the attachments are displayed in the reverse order of uploading, haha.
PostPosted: December 13, 2018, 5:57 am
Could not see the vid; "invalid parameters".
What dampers are you using? I'm always looking for cheaper alternative adjustable coilovers.
The top of the dampers should mount as far out as practical (i.e. effective angle). A low effective angle requires higher than necessary damping adjustment and stiffer/heavier spring rates to compensate. Yours appear to be about 50% effective at that angle.
Ideally, the rear damper upper mount should be forward of the lower mount to prevent a falling rate, where the suspension gets softer as it compresses (axle moves forward in bump).
A motorcycle engine may not be allowed in your state to title for public road use. Some have complained here that they could not get their bec on the road when they never asked about registration. It varies.
