I should have taken more pictures, but it was overall a busy day at the shop (read: Driveway) yesterday.
I finally got around to fixing my pedal dilemma. I had unknowingly built the pedal box too far forward, which meant the drivers seat would have to be scooted forward about 3 inches from where it looked sensible, steering wheel rubbing on knees but the gear shifter would be fine. So the solution was to either remove the whole brake pedal assembly and try to re-engineer (read: walk around cussing a lot) the whole pedal box, steering column hangar and therefore scuttle frame or to think like a chimpanzee. I chose the latter, and therefore I introduce to you, the; Bradney Pedal Extenderator (*#%& - see footnote)
(This next part is best read in the style of a British 1940's accent)
Made from the finest grade stainless steel in a whopping 5/16 thickness these pedal extenderator's are an ideal solution for those with short legs or lack of fore-thought in the design process. With literally 30 minutes of design heritage these extenderators are sure to make your daily drive, or track days a breeze.
Here you can see the highest quality of finish of these wonderful products, so that your car will not only look good, but feel good too!
And did I mention, they're adjustable?!
In this picture you can see them mounted on the previous pedal assembly, thus bringing the pedal pad closer to the rear of the car by 3"
In all seriousness though, it's a solution to the problem. I'm not a huge fan of the single shear aspect of the bolts, I think that once we have found a final comfortable position for them I will possibly weld them to the brake arms as well as upgrading the bolts from the grade 8's to some driveshaft bolts for there shear strength. Or maybe just upgrade the bolts. We will see.
It also was nice because bringing the pedals back a bit also allowed them to sit in the wider section of the footwell, thus spacing them apart became easier. In this next picture you can see with that some daily width shoes my feet can actually hit the pedals without interference.
Well maybe the picture doesn't really show it all that well but I can. Note that the brake pedal was eventually bolted up correctly, not just balanced on the bolts.
This solves the footwell issue, and makes the car more comfortable to sit in. I will however have to fiddle around with the location of the gear stick, and bring that back a touch, and I still might go for a slightly smaller diameter steering wheel.
I also made a few discoveries;
1- the seats that I bought from a guy in the dark without a tape measure to hand don't fit, they're 2" too wide. They will be for sale, or for another project.
2- My Dzus fittings are two different sizes, which explains why my scuttle was flip flap flopping about and my nose wouldn't cinch down.
Taco Tuesday - chicken, bell peppers, jalapenos, sour-cream and cheese in flour tortillas (because corn tortillas are just wrong)
* - Patent Pending
# - Copyright 2017
% - Trademark
& - Other BS so people don't steal my s**t
** -hi
