Ron- Thank you for the explanation (with pictures, no less!). I had always thought of that rear "hoop" of the traditional 7 chassis as some lightweight thing that only held up the aluminum skin. I see now that it must be more substantial than I'm giving it credit for. I also appreciate the explanation and pics of the mounting points and the fenders.
Chuck- Thanks for the "frame of reference" about the screw's strength. I mis-stated the concern with the fenders/screws. In reality, the concern would be the fiberglass fenders and the thin aluminum sheet they're attached to. As I discovered a few weeks ago when I had tire clearance problems, the screws held up just fine, but one of the rivets holding the body panel on gave up. I also found (later) that the holes thru the fiberglass fender had become somewhat elongated at that time. (The scars were fresh, it had just happened.)
I'm planning to mount the wing to the angled "downbars" on the back of the main roll hoop. THAT should hold that li'l booger up, doncha tink? Given the difference in design and attachment, I'm not going to put any of the aero load on my car's rear fenders. I'll probably use 1/4-20 machine screws because most of the removable panels on the car are held on with 1/4-20's so I have a bunch of them in the shop already. And because hillclimb...
One last (maybe...) question, Ron-- Do you know a number for the downforce produced by that spoiler? (Or your buddy's A-Mod wing?) For another "frame of reference". I've been thinking 200 to 300 lbs, based on stuff I read on the internet. (so it's gotta be true!) A friend of mine who has wings front and rear on his Westfield says he aims for 150lbs. He also says it's "track dependent" and I get that. But in general, ball park, rough estimate, off the cuff, your .02, etc, how much downforce does one need?
Thanks again!
JD, father of
Quinn, Son of a...
Build LogQuinn the Slotus:Ford 302 Powered, Mallock-Inspired, Tube Frame, Hillclimb Special "Gonzo and friends: Last night must have been quite a night. Camelot moments, mechanical marvels, Rustoleum launches, flying squirrels, fru-fru tea cuppers, V8 envy, Ensure catch cans -- and it wasn't even a full moon." -- SeattleTom
