It is currently April 16, 2024, 1:30 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
PostPosted: August 27, 2018, 2:18 pm
Hello everyone.
It's been 14 years since I started this, but here is a video of the first start:
https://drive.google.com/open?id=1YMj4q ... XoBfH4NNUh
details: Toyota 4AGE 1.6 liter engine, carbs from a Suzuki GSXR sport bike, W58 transmission from a Supra, diff from a AE86 Corolla GTS with torsen limited slip. titanium muffler from a Yamaha R1 sport bike.
Many thanks to the listers that posted all of your great ideas for me to shamelessly copy.
cheers
Doug
book 4AGE build, Supra W58 transmission, Corolla GTS live axle
PostPosted: August 27, 2018, 4:58 pm
Like it a lot Doug. Good work. The finish line is getting closer.
Larry in Seattle
PostPosted: August 27, 2018, 5:31 pm
Looking good Doug-
What kind of a muffler is that?
Roy
PostPosted: August 27, 2018, 7:58 pm
Good going! :yay:
PostPosted: August 28, 2018, 8:50 am
Great work Doug, like the grin on your face as you fire it up :cheers:
PostPosted: August 28, 2018, 9:05 am
She sure sound sweet.
And... 14 years? My hat is off to you for your fortitude. Keep at it :cheers:
PostPosted: August 28, 2018, 11:14 am
Thanks for posting the video - I'm using exactly the same muffler on my 2-liter Zetec engine, with 2 1/2" exhaust, and had no idea what it's going to sound like. Now, I know! Not bad...not bad at all!
PostPosted: August 28, 2018, 3:01 pm
thanks everyone.
To be precise, the frame hung from my garage ceiling for 6 years. (2004 to 2010). Then I spent one winter of spare time on it before I bought an old Jag, so the Locost got put on the back burner again for a few years.
Roy, the muffler is titanium, and was a new takeoff from a Yamaha R1 sportbike. Those guys like to replace their mufflers with carbon fiber, so it was essentially new, $50 plus shipping from Ebay. My friend Don used one on his Locost, with a 20 valve Toyota 4AGE, so I knew already what his sounded like. By the way, the engine was still cold when we took the video, and it revs a lot better when warmed up.
cheers
Doug
PostPosted: August 29, 2018, 1:27 am
Hey Doug
Looks like another garage get together is due with the guys.
Your thoughts?
PostPosted: August 29, 2018, 1:53 am
All you Alberta guys do nice work! :cheers:
PostPosted: August 29, 2018, 7:53 am
Nice job Doug :cheers:
That muffler does an excellent job on what is usually a pretty loud exhaust. What ECU are you using?
DaveW
PostPosted: August 29, 2018, 10:02 am
Good job. Interestingly as carburetors prove themselves on the road. Is the main fuel jet enough? or will it be poured? We put similar, it was necessary to tinker.
Do not be ashamed not to know, it's shameful not to know and not ask
"And even if they say " Yes, let them talk!
But no one - no one dies in vain,
This is better than vodka and from colds.
Others will come, replacing comfort
At the risk and inordinate work,-
Will you not passed route." V.S. Vysotsky
PostPosted: August 29, 2018, 10:28 am
Hi Perry
Yes, we should do another garage meet, but I will be on the east coast until Sept. 23. Possibly soon after that?
Dave, the ECU is called Nodiz from the UK. It uses a trigger wheel, and a Hall effect sensor from a Ford Escort. It is Bluetooth equipped so you can monitor or program from your phone or computer.
https://motorsport-electronics.co.uk/pr ... nodiz-pro/
Dave, question for you, what did you use for the radiator fan switch on your 4AGE?
The carbs are from a Suzuki GSXR, and I've changed the main jets to 1.5 mm per advice from http://danstengineering.co.uk/
cheers
Doug
PostPosted: August 30, 2018, 8:25 am
[Dave, question for you, what did you use for the radiator fan switch on your 4AGE?]
I first used a VW thermos switch, that originally went off at 190* [engine ran around 195*-198*]
I now have a Summit Racing thermos control switch P/N SUM 890018 Zirgo temp switch ($23.95). Zirgo is on at 200* and off at 180* controlling a 12" flex lite fan thru a 15 amp relay. This switch is screwed into the rear head outlet where the stock 4AGE had a thermo vacuum switch located above the heater hose connection. See picture, the thermos switch just below top heater hose. The water outlet casting is a slightly modified GTS part on a MR-2 engine.
My 4AGE engine likes running at the lower temp. The engine normally runs about 186* now.
DaveW
PostPosted: March 18, 2020, 10:01 pm
Hello everyone.
Here's a photo of my almost finished 7. I had it licenced last summer, but over the winter I built to hood and painted the nose and fenders.
Currently building an aluminum trunk cover and lid. The tricky part it to miss the rear members of the roll bar, but I think I have it figured out.
cheers
Doug
Users browsing this forum: No registered users and 27 guests
