Thanks for the tip MV8. I think I will run a bead of weld along the top of the upright bracket to the 1/4" tab that had been intended for the UCA attach point and leave the thru bolt as configured. That should be very rigid.
Spring is finally here, and as many of you may have noted, we returned from our Wisconsin COVID hideaway to the Boston suburbs for my wife's work (she had been able to work remotely) where the Locost is. So, I have been back at work on the car.
I am now working on the exhaust. I went back over Nick47's web site and saw his progress over time with the exhaust changes.
My questions to are which muffler choice to make.
When I acquired MGB the motor from my friend, he also included an almost new exhaust system with a header pipe, resonator and stainless muffler. It had been an aftermarket system purchased thru Moss Motor. The resonator is a small, long bullet style unit. The muffler is a large round can with a polished stainless case.
I had thought about installing the resonator on the side next to the body, like yours. Then trying to sneak the 1 3/4" tube under the frame at the wheel arch and place the stainless muffler across the back under the rear of the car. This would reduce the size of the muffler hanging on the side and move a lot of the exhaust noise to the rear of the car.
Some of the original Caterham 7s had this config.
Caterham had the large muffler at the side and a resonator in the rear.
But, as the photo shows, the ground clearance gets very close where the tailpipe tucks under the frame close to the inside of the tire.
My other two choices are:
1. Use the stainless muffler as I show in the earlier mockup post, mounted to the side and use a 90-degree exit just before the rear tire.
2. Use the smaller resonator muffler on the side and use a 90-degree exit just before the rear tire.
As Moss motors described the exhaust system back when, the resonator reduced the high tones, and the muffler reduced the low tones. So, as a system it would give a mellow tone on acceleration and cruising. Using just one or the other will change the overall effect.
The last photo shows the muffler across the back. It will tuck up a little tighter into the back than shown.
Would love some feedback here from the group!
