BHRmotorsport wrote:
Unless it's a coincidence and everyone that clicks that link gets an ad for a Bosch MAF.
I get no ads went I clicked on that link. On another note Canadian Tire stocks it for us Canucks.
rx7locost wrote:
As far as anything on the 'net is concerned. If you aren't paying for the product (i.e. Google), you are the product!
Yes we are being watched, just think, those satellites up there can read news print at ground level. Knowing this I don't walk around buck naked outside anymore.
In the shop today for a bit. So.... I've approached this build a bit differently. I'm cleaning, rebuilding, re-sealing all the major components before I start cutting steel and gluing it together. This way I'm not working with oil, dirt, grime, slime covered parts when fitting them to the frame.
Finished up with the transmission today.
Removed the axle bearings, sand blasted the flanges, then some paint.
Sand blasted the rear brake backing plates, then some paint.
And for those of you who are thinking of coming north of the 49th, this is what we had fall out of the sky today.
