botbasher wrote:
217 Racing wrote:
Great idea with the hinge man. I might have to steal that idea from you
Just a possible concern you might have addressed already.
Is that bolt simply threaded into that nut? I would think that it would back out under normal vibration.
Maybe a longer bolt with a double nut on the other side, or drill it and safety wire it.
Just would hate to see the nose get loose.... especially at speed!
KS
LOL!
I was wondering who's going to be the first one to point out the potential problem with my fastening methods, turns out it's you
I was too lazy last night to post the entire thing but the nut is actually welded to the hinge, the bolt needs a couple of nylon washers and will get a drop of loctite on final assembly.
Safety wire is a good idea - if you have access to remove it when needed.
I won't have access because of the radiator ducting, that's the reason that I welded the nut to the inside of the hinge too.
Thanks for the link JD, I haven't seen that one before.
I't not too far off what I want but at $170 the cost is higher that than what I want to spend.
I started doing some research on a home made squential shift lite and already found some stuff... this should be a doable thing, it ain't rocket science (famous last words
Moti
