It is currently May 25, 2020, 7:47 pm
Post new topic Reply to topic  [ 581 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 39  Next
PostPosted: December 10, 2007, 12:08 pm
Weight watcher
Hey Kurt -
I decided against using these calipers because of the ultra tight fit.
The miata calipers fit with at least 1/2" gap from the rim and the spokes.
The wheel isn't a "multilug", the extra 4 holes are there probably to make it lighter, they don't have a flange to seat a lug nut against.
I've never heard of an issue with those, I guess I'll see when I get there.
BTW, my car is being built as a track-only car, no street use.
Moti
Moti
PostPosted: December 10, 2007, 12:19 pm
The wheel issue is something I've heard from a few people about; they weren't allowed to run at the track with them. I'm not sure whether the extra holes are for lugs or losing weight matter, as it's (rightly or wrongly) considered to weaken the hub area. I'm not trying to rain on your parade, just letting you know there could be an issue with some organizations.
PostPosted: December 30, 2007, 3:58 am
Weight watcher
Finally got some progress made.
I've been waiting for my JD2 bender to show up for some time, they just moved their plant from FL to TN and got all backed up on orders...
So, I've mocked up the cage in PVC, took some measurements, read and re-read the rulebook and went to work.
The extra frame member I added between the front mounting plates is because I didn't like the idea of loading a single tube in the middle, I'd rather load an intersection.
I might need to lower a section of it later to allow easier access to pedals but I already have an idea how to do it if I need to.
Comments are welcome!
Moti
File comment: Measuring my height with a helmet in my seat.
I swear I didn't make any "vroom vroom" sounds!
File comment: One of the small details that bug me are holes left at the back of the A1 and A2 tubes where they meet B1, So I cut B1 long enough to integrate caps for the A tubes.
File comment: One of the rear mounting plates as a cardboard mock-up and the final piece.
File comment: At this point it's solid with all tubes welded on the top and the bottom.
There's absolutely ZERO warpage, it sits completely flat and perfectly square.
I'm happy.
File comment: The crazy locost ninja star mounting plate before bending, karate kid ain't got nuttin' on me!
File comment: All mounting plates are tack welded and I can start bending the cage!
Tomorrow morning... oooohhh I'm excited to use my new bender!
Moti
PostPosted: December 30, 2007, 4:43 am
Man, I really gotta say looks good. I like the mounting plates idea....
What gauge steel are you using for the mounting plates?
Why does the roll cage stop at the knees? Any thoughts or opinions to extending it to the feet too? (Just a question, not trying to open a can-o-worms)
I'll keep an eye out for you!
To err is human...
I am more human than most.
PostPosted: December 30, 2007, 11:29 am
Weight watcher
Thanks!
The plates are 1/8" like NASA and SCCA specifies in their rulebooks.
The front hoop is located about halfway between the knees and the feet.
I didn't want to have it any further forward than that because I felt that the sides are becoming too open.
I can always extend the side bars beyond the front hoop, that is one design that I've been considering.
Moti
Moti
PostPosted: December 30, 2007, 2:41 pm
Those plates are great! They look very professional.
Just wondering, did all your steel come that clean? or did you have to clean it?
Georgia Tech
Ride and Handling Engineer for a major car company
Locost finished - book frame, IRS, '84 celica GTS donor, '99 tacoma 2rz motor with a turbo, megasquirt DIYPNP. Getting rebuilt with new IRS, F20C
PostPosted: December 30, 2007, 3:37 pm
What eVox said, plus how'd you bend them?
PostPosted: December 31, 2007, 2:19 am
Weight watcher
Thanks again 8) .
eVoX -
While the metal is just being stored I just keep the oil on it but I clean every piece of metal with an industrial type metal degreaser before I handle it with any tool.
It keeps the tools clean too and I really like the fact that my build table doesn't have any oil on it...
Even after cleaning, once the fabrication of the piece is done and it's ready to be tacked, I clean it again and run every section that will be welded through the wire wheel to assure that the weld will be as clean as possible and minimize contamination.
Jack -
I negotiated the pieces into shape in the old fashioned way, a vise and a 3 lbs sledge hammer :lol: .
Working the piece slowly into shape.
Moti
Moti
PostPosted: January 3, 2008, 2:01 am
Weight watcher
Well, after a good bit of work I'm done bending the main hoop.
I'm kind of amused about going straight into bending a compound shape, why would I start with something simple if I can go straight to the royal PITA?!
:lol: :lol: :lol:
Truth is, it took me forever to get it right, but I did it!
The angles are correct and the whole thing is well within spec with only about 1/16" differnce between the two side, if even that.
Here's a link to an online guide that I found a while ago and was very helpful -
http://www.pirate4x4.com/tech/bendin_tube/index.html
Moti
File comment: There ya go!
Man, this was hard to get right.
File comment: I followed the method described in the link, only I wrote on the tape instead of on the floor...
Moti
PostPosted: January 3, 2008, 2:17 am
So it's all downhill from here out, right? :wink:
PostPosted: January 3, 2008, 2:31 am
Weight watcher
At least in case I need to bend anything! :wink:
Moti
Moti
PostPosted: January 14, 2008, 1:02 pm
Weight watcher
[read like Borat]Great success![/read like Borat]
Finally the magic combination of having free time and good weather occured and I was able to make some progress with the cage.
Both hoops are tacked in and are lined up pretty well.
Yes, it was a major PITA but I'm glad I've done it this way.
Up next, adding the rest of the cage braces which should be much easier to produce - most of them have only one bend in them or non at all.
Moti
File comment: The template method described at Pirate4x4 proved again to be really easy to follow, I highly recommend it (see link in a previous post on this page).
File comment: Tube lined up with the template.
File comment: The compound miter saw makes compound cuts like those really easy, it's 6.5º miter and 18º bevel.
File comment: Note how the tubes are lining up.
Pretty dang good for a first time...
File comment: I tried tilting it in various angles up to 30º and eventually settled on 18º which seemed to work best for me.
File comment: Both hoops are tacked in! woohoo!
Square tube on the side hanging just for the sake of trying to determine angle of side brace.
Moti
PostPosted: January 14, 2008, 11:10 pm
Louisville's luckEseven Lauds Locosts
Moti,
Looks great! I love the idea of integrating the roll cage into the structure, I only wish i had heard about it when i started my build.
Nice job with the tubing bender, any chance you have any pics of that set-up?
Also, you mentioned an "industrial metal degreaser", care to share what that is or where you can get it? Thanks!
-Emile
Scratch building an IRS, RX-7 based book chassis @ myBuild Log
*Make way for the luckEseven!
PostPosted: January 16, 2008, 3:30 am
Weight watcher
The bender that I have is the JD2 model 3.
I just got it and this is the first thing I made with it.
I made my own pedestal for the bender and was pretty surprised to see at first how much twist I got in the base plate of the stand.
Once I got some extra bracing on it the thing became rock solid which does help when you're coming to set up a tube for bending.
As for the degreaser, I got it at my local metal supplier, IMS.
They carry their own stuff but I'm sure yo can find similar products at metal suppliers or welding supply stores.
Moti
File comment: JD2 Model 3 bender
File comment: Reinforced base
File comment: IMS degreaser
Moti
PostPosted: January 16, 2008, 10:10 am
YARRRRR! nice touch with the jolly rogers :lol:
