RandyBMC wrote:
So you need a bolt that has an OD that fits exactly inside the ID of the control arm, and the heim side threads into the bolt center that you drilled and tapped?
Pretty much, yes. The sizing of the bolt may differ depending on the rod-end size used. The 3/4" bolt drilled and tapped to a 1/2-20 thread happened to have slightly more axial strength in the drilled area than the rod-end it was attached to;
I'll throw out the caution that if the rod-end's axial strength exceeds the axial strength of the drilled bolt and the rod-end is loaded to its limit, the bolt may fail at the end of the drilled hole and cause the suspension to come apart.Also, keep in mind you will be inducing bending into the rod-end's shank so it is probably a good idea to at least step up to a stronger alloy rod-end. You'll probably also want to make the tube the bolt slides into thicker than the normal 0.063".
RandyBMC wrote:
Does the bolt that you cut reach all the way to the end of the control arm "carrier" for the bolt?
I made mine approximately 1/8" shorter than the tube at the end of the arm. Anywhere between 1/16 and 1/8" should be fine. You just don't want the jam nut on the rod-end to clamp on to your custom bolt since that won't prevent the entire assembly from sliding or rotating within the arm.
RandyBMC wrote:
What does the lock nut on the heim lock down on?
On mine, it clamps down on the tube at the end of the arm (the head of the bolt is at the other end). You'll want to use a washer that is at least 1/16" thick with the same OD as the arm's tube to prevent the nut from pulling into the tube when its tightened.
