Another update:
I drove down to RandPCarriages in Seneca Illinois for the trailer parts I am using. I found them on eBay but wanted to look at some of the stuff before pulling the trigger. I picked up the electric brakes, hubs, various lighting products and wiring bits. I can't say enough good things about these guys and gals. We just walked thru their warehouse with my list and said "yes", "yes", "no", etc. as we went. I ended up with more than was on my list.
The basic frame mods are done. The axle was extended 27 inches. I cut the axle and measured it as 2-3/8" OD and 'zactly 2.000" ID. I purchased a 12 inch piece of 2" x .120 wall tube and cut it in two. Then I purchased a piece of 2" Sched 40 pipe. this is 2-3/8" OD and ~ 2.07 ID. I tapered the axle and pipe for welding and drilled 3 radial holes, 2 inches in from the ends with a 3/8 inch drill for rosette welds. The 6 inch pieces of tube were driven into the axle ends with a rawhide mallet. The pipe was then fitted leaving about 1/8" gap to the old axle. This allowed the welding to penetrate the axle, pipe and tube insert all together. I lifted the pipe until it was constrained by the ID/OD mismatch of the pipe and tube. This replicated, to the best of my ability, the pre-bend that was on the original axle.
The rust was wire-wheeled off the frame and primed via brush with Rustoleum heavy rust primer. The leaf springs were taken apart, cleaned and painted, then reassembled using a light amount of silicone grease on the leaf ends. Then I offered up the axle assembly to the chassis and secured it into place. I mounted the new Electric brakes and then the new tires.
I disassembled the surge brake coupler and decided that I will re-engineer that for the new application. I removed the hydraulic parts. If I remove the coupler slide, and rest it on top of the outer case. When welded in place, it should be at the right height for my hitch ball.
I picked up some treated 2x10's the other day for the bed. Next up is the framing for the bed.
