It was a rough day at the Misadventure Machine Shop, but in the end, the day was saved by good old American stupidity. Our motto is "We're too dumb to fail" and every once in a while we prove it.
I'll have to digress for a paragraph or two, but it will come back together later on. A couple of months ago on a visit to my favorite San Diego metal supplier, I found some really cool DOM tubing in the remnants section. It is 3/8" outside diameter, and an almost perfect 1/4" inside diameter. I said to myself, "Self, that is just too handy to pass up", and I bought the only piece there. It was about 13-14 inches long.
When I started my pedal box design I decided I would use it in two places on each of my pedals; clutch and brake. So, out to the garage I went and verified the dimension again with my fancy digital caliper. I put it in a place I was sure to find it when actual construction of the pedals began.
Design work was completed and construction started late last week. It came time to actually cut the 3/8" DOM tubing to the required sizes. I looked high and low, left and right, front and back and maybe a little upside down too, as I checked that it didn't roll under something like my work bench. I could not find it. OK, time to go to Plan B, which is to drive to San Diego Saturday morning and buy some replacement DOM tube from the supplier's virgin stock. I needed some other partial sheets of 16-, 14-, and 12-gauge sheet too, and I'd get it all at the same time.
Wrong! They don't stock it. It's a special order. But, they could have it in 7-10 days. So, I came back home with the steel sheet, but no 3/8" DOM. That meant my smallest tubing was 1/2", 16-gauge, welded tubing I already had back in the garage.
OK, the world give you lemons, then you make lemonade, right? That's where stupidity comes in to play. Unbeknownst to me, someone started a wormhole in the Bubba-sphere Saturday night, and Bubba escaped from Tallahassee and took the red eye flight to Carlsbad. Whereupon, he sat at the end of my bed and filled my dreamy head with bad ideas about how I was going to overcome things and make this stupendous set of pedals incorporating 1/2" tube instead. So, with out further delay, here is the plan and the way it unfolded. DO NOT REPEAT THIS AT HOME.
I carefully laid out the clutch pedal (it's the simpler of the two) on 12-gauge sheet. I took a slightly larger piece and tack welded it underneath my accurate "Master" layout.
The plan was that I would drill and cut both pieces together getting a sure fit-up and pretty much identical left and right pieces for the pedal.
So far, so good. Then Bubba's idea came into play. I'd cut away a lot of the waste material (actually, I save it all and make tabs or brackets from small pieces) with the pieces tacked together. I'd leave enough tack welds to keep the plates lined up and then bolt them to a sacrificial piece of wood and then cut the profile of both together. I should have sacrificed Bubba instead!
This was not a good idea. And, Bubba didn't realize my band saw blade was too thick to cut out the nice pattern I laid down with out twisting and generating a world of friction and cause groaning of my poor, tortured saw blade. But we was committed (not to the asylum like we should have been) and had to keep moving forward.
There is a reason what the band saw table is solid cast metal. The vibration, twisting of the blade, friction and heat using the sacrificial wood was not good. I tried to be as conservative as possible, cutting the curve for 1/2" or so and then trimming away the waste to reduce friction. It worked, but I was fully expecting the saw blade to break and the severed blade would take off a finger or finger tip. While I was working, Bubba low-crawled out of the garage, and returned to Tallahassee. I plan to Spackle Putty that wormhole before I go to bed tonight!
Once cut, I proceeded to hand finish the two parts and then loosely put them together with the 3/4" and 1/2" tubing I had cut for that purpose. All-in-all, it all turned out pretty well. However, I'm planning a different approach to the brake pedal, which will be more critical because of the large forces generated during any "panic " stops. I still need to machine the lower spacer and "axle" for the bottom of the pedal, and for the curved foot pad to be welded on the end. Still, all things considered, it's not a bad job for a first time fabricator.
Bubba has been fired and tomorrow is a brand new day!
