I spent the afternoon sitting at my desk (actually my portable welding table cover with cardboard top) right at the front of the build table. This is the way I like to work. I sit there, try to visualize what I think would work best, mock it up somehow using wood, plastic, cardboard, or whatever works. Then evaluate how well I think it will work, and can I actually make what's required?
I have a true one-off build, and I've got to solve some unique issues with my donor parts. I have some really cool software to help with the designing, but you've got to feed it real data to get meaningful results. That means mocking things up, measuring from certain datum lines I will set up, and inputting the accurate data to the software. So, I'm going to embark on a little development program, which will take me some time. Given all the variables, and the many iterations I'll need to try, I'm thinking it's going to be a month (at least) before I have a finished product in metal.
That's OK. I gave myself permission to take that time this afternoon. Otherwise, I'll push too hard to get something quick, and make too many compromises. I don't want to do that. I've got years into this project. With COVID-19 isolation, I don't have a lot of other stuff to do anyway. I'd rather be thorough and get a good result.
I like to visualize/mockup/measure/observe as a methodology. I find I arrive at better solutions that way. One little issue I rediscovered today is the steering rack location and tie rod angles. With the wheelbase I decided on, the rack has to be just on one side or the other of the front frame. The realities of that is that the tie rods will need to sweep slightly forward, or slightly backward, depending on which side of the front frame I mount the rack to. The long rule in the photo simulates the general arrangement if the rack is at the back of the front frame - almost certainly where I'll put it.
It's going to be a challenge to get everything lined up as needed to avoid all steering effects. I've always planned on a custom rack, and that's probably the best solution here anyway. So, tonight I'll make myself a nice drink, and tomorrow, start my development program.
