monte montemagni wrote:
Hey Lonnie:
Under the FWIW column: You might want to consider a bit more strength on the end sections. Not needed at the moment but when you start mocking up the real parts, the weght of the motor, differential, tires, suspension does add up and likely to be concentrated at the ends by blocking the chassis up for trial fits, etc.... Just a thought. Otherwise, as far as I can see it resents the bar for work tables !!
Hi Monte,
Happy New Year to you and yours.
Thanks for the interest and the comment. In the photo just above, the front of the table is closest to you as you look at the picture. It isn't at all obvious, but if you look back on page 13 of my build log you'll see a 3D model of the chassis sitting on the build table. You'll recognize the pads for the motor mounts in the 3D model. They sit right above the front truss and the weight on those pads is taken directly into the legs through the truss. The only weight forward of the front truss will be the radiator, a small part of the chassis, front suspension, steering and sway bar plus the nose cone and horns and a few small items. It's a pretty light load, all-in-all.
The middle truss is just behind the transmission mount and right under the (B2 or BR11) cross member. So, a huge majority of the mechanical components including most of the chassis weight, dash, steering column, engine, transmission, etc., is between the first two trusses. That's why they're stronger. This is really a combination build table/chassis bench and I intend to assemble the entire car on it, cutting away the plywood as needed once the basic chassis is done, and aligning the mechanical components while doing so. The longitudinal trusses are open enough to allow me to squeeze through from the sides or alternately go from the back to get underneath and work.
Between the middle and last truss, it's almost all the rear half of the tunnel, cockpit, driveshaft, seats, etc. That is, not all that much of a load. The 3rd truss is directly under the B1 (Book) or BR12 (Haynes) cross member. The only things on the rear cantilever section, aft of the 3rd truss, is a small percet of the chassis and seatback, the rear axle, chassis kick-up (light tubing), gas tank (empty) and the rear aluminum bodywork. Perhaps in all 325 pounds, worst case. However, I'm planning to make some temporary "jack stands" of wood for each of the rear wheels to sit on when attached to the rear axle, so I can play with the ride height while I do the mechanical alignment. I think the real weight on the cantilever section will be less than 200 lb., except for brief periods of time.
I also have in mind that I'm going to build a second chassis at a later point, but not for the street. That's why I'm willing to make the investment in a semi-permanent structure now and will probably sell it to someone else building a Locost after I'm done with it.
That's the hope and the plan anyway.
Regards,
