TRX wrote:
If it was me, I'd shove the engine back and down as far as practical and worry about hood clearance later.
The scuttle/nose/hood line can be raised, you could cut a nicely edged and shaped to clear any protruding plenum bits, there are alternative factory intakes available, and if it comes down to it, you can modify the stock intake. It's only moving air, and it's not rocket surgery...
Some years ago I built a sheet steel upper plenum for a 3.8. I cut a bottom plate out of 1/4 steel flat, holesawed and ground the holes to match the lower plenum, sliced a piece of 3" muffler pipe lengthwise to make left and right sides, welded a top, back, and a front plate that had provision for two small throttle bodies. It's still out in the shop somewhere, but I'm still on crutches and can't negotiate the steps to get out there and take a picture of it for you for another few weeks yet.
It's less work and takes less skill than welding up some Locost A-arms.
Don't stress on the freakin' intake! "Ve haff vays off dealink mit zuch problemz!"
The truth will be told pretty quick here now. The woodworking tools are all set up, and tuned up, and the mock-up is going well. I'm going to leave out the tranny tunnel and some other pieces until I get the engine and transmission in place. I know there will be changes there for sure and there's no point in making it all just to tear it out and redo it again. The mock-up will be my rough design tool and then I'll finalize on the computer thereafter.
