cheapracer wrote:
1) No need to offset the trans, just run the shaft at an angle as long as the longitudal line of the diff and trans are pretty much paralel there won't be an issue
2) As above
3) skid plate is fine, no need for roller.
4) 3 degrees is ok
5) again up to 3 degrees is ok
Great idea with the wood mockup, big time and money saver.
Hey Lonnie, is there anyway you could weight the engine and trans? Preferably separately.
The world in general seems to be short of real world engine weights.
Thanks for the responses, cheapracer. I don't know yet, what the best setup will be in terms of the multiplane angles, that's really why I'd like this mock-up to be accurate. If I can do it right, It will allow me to do a number of things including study the effects of tire size (rolling radius) on the angles required by the driveline including the differential angle.
The stock Mustang tires and 15" wheels are pretty good sized. I just plan to pump them to the max (45 PSI?) for a larger radius and take air out to flatten them down to get a smaller radius. I'm going to mount them to the diff and roll the whole live axle, wheels and all, into place above the MDF. I'll use some simple screw-driven device to change the pinion angle by placing it between the MDF and the driveshaft flange. I'm hoping there is a near optimal combination for offsets angles and tire/rim sizes.
And, yes, at some point I'll weight the T5 separately. I was surprised to find weights on the Internet ranging from 95-130 lb. for the T5. In fact, I did call around to rental shops to see if somewhat had a scale I could hook between my shop crane and the engine, but couldn't locate one. Our bathroom scale won't handle the engine, that's for sure.
