Work continues. I didn't want you guys to think I'm slacking, so here's a couple of screen shots from my 3D package today.
As you'll see from the screenshot below, the arms are parallel to each other and level with the ground; classic Locost position.
So, given what I've been saying I wanted to do, namely non-parallel trailing arms, what gives here? It's just a way of making sure the structural landing spot for the forward end of the links ends up in a place where my adjustable mounts have enough real estate to work. The 3D model is actually easier to work with than the real chassis for this kind of detail. The current plan is to have enough adjustability to go from understeer through neutral steer to oversteer by manipulating the 4 front mount locations.
I've learned a lot and done a lot of figuring and calculating, but haven't finished my design yet. I did discover that the classic, equal length, parallel and short trailing arms have a lot of positive characteristics save one; probable binding near the end of travel during bump and droop. You all know about that from Cheapy's experiments.
In practice, the lengths of the arms have much less effect than the angle of their inclination and virtual intersection point or "instant trailing arm center" and the inclination of a line from the axle center to that imaginary point. I'm thinking of writing a "Locost 4-Link Implementation Guide" where I lay out all the stuff that I've learned with references to various sources like books and the Locost USA website and build logs. Actually, I started it, but stopped because I was doing a lot of writing and no designing.
My current search is for the best spread of the forces across the structure. I can fix up the geometry to do what I want thereafter. After today's work, I believe I'll shorten the upper link about 2" and run the lower link forward several inches to better tie into the diagonal from the lower rail to the seatback nearer their junction. The longer lower link will effect my pinion angle, so I'll have to be on the watch for that.
After that, I've got to do my adjustable front mounts themselves (I have those pretty well noodled out), the jacking screws for the ride height (have ideas about those) and the Panhard rod mounts. I was thinking I'd get a 5" roll center at rear with a straight Panhard rod running from side to side, but that does not look as practical now. My axle bracket would have to be too long and extend down below the bottom rail of the chassis rail an inch or more. I'm thinkin' 6" roll center now and having the Panhard rod sweep forward at an angle to shorten up the axle bracket rather than run side-to-side.
I'm sorry to see several guys drop out recently and list their partially completed projects for sale. I've been on here quite a while, but I'm going to stick with it until it's complete. The fact that I've done a custom chassis with a novel donor has cost me a sh*tload of time because I have to learn each design topic as I go, then come up with new solutions to fit this unique situation. However, on balance, I think it's been worth it. I'm knowledgeable and competent on several subjects I'd be clueless about otherwise. There's more to go too. I still don't know enough about braking systems or (big gulp) programming/re-programing the ECU. There's always another hill to climb isn't there?
