It is currently March 24, 2019, 3:21 pm
Post new topic Reply to topic  [ 1976 posts ]  Go to page Previous  1 ... 124, 125, 126, 127, 128, 129, 130 ... 132  Next
PostPosted: October 3, 2018, 11:20 pm
Here are the photos of my finished undertray just before I put primer on it.
File comment: Completed undertray: welded; ground; and prep'ed for bare metal primer.
I didn't do a welded "X" on the most forward portion of the footwells for a good reason. I haven't done my front suspension design and brackets yet. I need the chassis to lie as flat as possible when it goes back on the build table, so I can complete that work, and other features.
My strategy for the grinding and finishing was to get all the welds close to flat with a very aggressive 40 flap disc. Following that, I used a conventional grinding disk to get it very close to done. The rigid disks are easier to control for fine work. The last step was to use a relatively fine 120 grit flap disc to smooth finish the welds and gently round them over to meet the side rails of the chassis.
File comment: Drivers' side of undertray looking to the rear.
File comment: Detail of finishing and rounding of welds. I used a very small machinist square to make sure the future body panels will break square when built.
Besides the chassis structure itself, this was the most demanding and labor-intensive part on the car thus far. Oy vey, sick of the grinding! I think Scarlet O'Hara said it best:
I'm with her - at least for a day or two. :mrgreen:
PostPosted: October 5, 2018, 8:49 am
Looking good Lonnie.
Comment: with the staggered weld along the outside edge, You've just set the method for forming the aluminum body. To get a nice crisp corner, you will have to form that bend off the car. Not an issue if you were planning on doing that anyway.
PostPosted: October 5, 2018, 9:54 am
@rx7locost
Thank you, Chuck.
I'm taking an unusual approach to the bodywork. My first effort will be to quickly do some temporary body panels just to get past my State inspections. Martin (hassleweed, San Diego, CA) found some inexpensive, pre-painted panels at a local supplier that I'm going to use at first. You can see his work here viewtopic.php?f=35&t=8967&start=45 . I'm going to attach them in a temporary manner just to cover the chassis and leave off the hood all together. I have a fiberglass scuttle and nose section from Kinetic. If the panels are just OK looking, that will be fine.
The State tests are static and you don't have to take the car on the road, otherwise it wouldn't be safe to do it.
Then I'm going to take my time and develop the "real" body work using removable panels attached in a manner similar to what another Martin (mgkluft, B.C., Canada) did with his. It's going to take me some time to get my metalshaping skills going, so I want to get it legal ASAP.
PostPosted: October 5, 2018, 10:26 am
I fully welded that area and ground the welds flat just like you did. then formed around the corner and drilled/riveted thru the floor and tube. I was just pointing it out. Sounds like you have a plan. :cheers:
PostPosted: October 6, 2018, 9:49 am
@rx7locost
I appreciate the tip. Chuck. I hope I didn't sound defensive. I had actually given it some thought as I've been looking for ways to short cut the path to registration with out having the final work done.
Also, the "check's in the mail."
PostPosted: October 7, 2018, 12:20 am
Are you sure your ancestors aren't from Canada? :lol:
Hey Lonnie, sorry, just kidding, I'll bet if we go back 2-3 thousand years we're most likely related, along with JD's ancesters. :lol:
PostPosted: October 7, 2018, 4:38 am
Geeze, what did Lonnie do to pi$$ you off that bad? Heckuva thing to say about somebody... :rofl:
Peace, Love and "One Big Happy (Dysfunctional) Family" --
PostPosted: October 7, 2018, 8:26 am
Lonnie-S wrote:
@rx7locost
I appreciate the tip. Chuck. I hope I didn't sound defensive. ------
Nope. Not at all.
At the risk of sounding "Canadian", I hope I didn't sound condescending. There. We're even. :cheers:
Carry on.
PostPosted: October 7, 2018, 8:36 pm
Uh, actually they were on my father's side, Perry. But, to be fair, that was before Canada was Canada. They called it Acadia back then. :wink:
GonzoRacer wrote:
I dunno, JD. I have some relatives who moved around in the Mobile, Pensacola, Tallahassee region. We could have had some intermingling back then. :lol:
rx7locost wrote:
. . . carry on.
Yes sir, as directed.
I did get to my near term goal of getting the major chassis features done, and getting my build back on the build table where I can complete the suspension and other features like the scuttle hoop, steering wheel setup, seats and the boot of the car.
Due to the way my rotisserie was attached to the chassis, the front bay of the lower chassis was without any triangulation. I had build a piece to do that out of 1/8" plate some months ago. Taking it off the rotisserie provided a chance to put it in place. I did a pattern of 1/4"x20 weld nuts on the continuous reinforcement, so that later on I can build a cover of perforated metal to keep debris and bad things from coming up into the engine compartment uninvited.
File comment: Un-triangulated lower bay of the chassis.
File comment: Continuous triangulation piece.
File comment: Piece welded in and painted with primer.
So, after the primer was dry enough it went back onto the build table, but is on blocks. I need to re-level and modify the table to provide access to the new features welded in since initial construction way back when. It's likely to be 2-3 weeks before I get back to it.
File comment: Back on the build table for future work.
PostPosted: October 8, 2018, 2:06 am
Good job Lonnie, wish my shop was that clean :thmbsup:
PostPosted: October 8, 2018, 11:16 am
Lonnie, are you using weld-thru primer?
PostPosted: October 9, 2018, 9:31 am
@horchoha
Thanks, Perry. I'm glad I didn't take a photo last night. I had to put everything in the garage on the build table side, so mama could park her car, and there is room for the company installing the ceiling storage racks to work. It looks like a hoarder's garage this morning.
In a couple of weeks, I should have a much better setup. In a few months, when I no longer need the build table and can reclaim the steel, I'll turn my side into a real, organized, working shop space. I can't wait.
@ngpmike
I've seen those product advertised, but haven't used them yet, Mike. I'd need to know more about what happens to them after welding to feel like it's worthwhile.
PostPosted: October 9, 2018, 9:46 am
Thnx, Lonnie. Just curious.
PostPosted: October 10, 2018, 3:31 am
:lol: That's what I thought. Finishing the project $$$$, organizing the garage $$, keeping the wife happy $$$, keeping the build table - priceless
PostPosted: October 21, 2018, 8:21 am
Y'all would not believe the leaves/trash/water that can get blown into your shop, even with all the doors and windows closed, during one little hurricane... :ack:
JD
