It is currently February 16, 2020, 3:38 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: January 12, 2009, 6:54 pm
Ok, I've been pretty lazy about doing a build log. Figure I'll start small, and just post a little at a time. I'm well into the process of building a Haynes Roadster. My goal is to keep as close to book as reasonable, and not get bogged down on designing things with my first build. I also love the look of the 50's race cars, and will be going for the vintage look as much as possible. I've had an MG Midget all through high school and college, and wanted something British, but a little more modern in mechanicals. I didn't use a donor, which drives the cost up, but allows me a little flexibility with parts and room.
Here are some parts that deviated from the book.
2006 2.0 Ford Focus Duratec
2006 MX-5 6speed transmission
60s MGB rack and steering column.
Civic Radiator
GSX 750 Throttle bodies
TBird SC rear disks (TBird turbo rotors)
BMW motor and transmission rubber mounts
Mark
PostPosted: January 12, 2009, 7:13 pm
I'll start with the current status. I've been spending a lot of time trying to get the suspension and steering done. The means lots of bead blasting, pickling and painting of old parts. I'll get coil overs later, when I can corner weight the car. I also bought new bearings and seals. Rebuild kits for calipers, etc. Here are a couple pictures.
The suspension pieces attached:
The cleaned up and painted Merkur Diff:
My pedal box:
A couple of scuttle pics:
Kirkey vintage bucket:
Minilite replicas:
The steering column and rack:
Mark
PostPosted: January 12, 2009, 7:19 pm
It's hard to see in my previous post, but I cut the casting on the steering rack a little short. It's about an inch smaller than I want, which allows to much travel in the rack, but more importantly puts the column and u-joints a little close to the engine. You can see a little better in these pictures:
I have a rack coming from Keith Tanner that I may try to cut a little less out of. Note the rack itself is the right length, I just cut to much out of the casting.
Mark
PostPosted: January 12, 2009, 7:40 pm
Nice looking build. That Duratec should be a great engine.
What year is your MGB rack?
PostPosted: January 12, 2009, 9:06 pm
How much do you suggest taking out of the rack, also? Where did you do the cutting? Any Pix of this?
Mark
http://oldbritishmetal.wetpaint.com/
http://www.flickr.com/photos/michmark/
PostPosted: January 13, 2009, 7:42 am
I don't recall the exact year of the rack. Maybe 65? My invoice says 63-74.
I gave the machinist the finished length, I think he took out about 4 inches. The exact length is given in the book. I took the rack to Rod at http://www.onthegroundperformance.com/, he is only a few miles from me. I can look, but I don't think I took any pictures of the rack while it was apart. If there is something specific you are looking for, let me know. I have another rack on the way that I will take apart. Note, I had the pinion shaft shortened also.
Mark
PostPosted: January 13, 2009, 12:36 pm
Weight watcher
A nice build like yours deserves a nice radiator fan :wink:
Moti
Moti
PostPosted: January 13, 2009, 12:47 pm
Mark,
Great to see started a build log. I've seen several of your posts here and on the Haynes Roadster site, your build looks real good so far. Keep up the good work.
-IndyJoe
Starting a Scratch Build - ThunderBird Turbo Coupe Donor Car - being dismantled
Build Log Started: http://www.locostusa.com/forums/viewtopic.php?t=4914
PostPosted: January 13, 2009, 7:36 pm
These are the best pictures I could find of the rack. This is before I cut the pinion shaft. You can see that I cut to much out of the casting.
PostPosted: January 20, 2009, 8:35 pm
I was out of town this weekend, but had off Monday and Tuesday. So I got some work done on the steering rack. I also took some measurements for the drive shaft and the half shafts. I hope to have the work done next week on the driveshaft.
File comment: The "new" rack the I got from Keith with 3" cut out of it.
File comment: This is how much I can add back into the rack housing at about 38 degrees of wheel turn.
File comment: steering at full lock with the current rack housning, about 45 degrees.
File comment: Clearance between the engine and steering shaft with current rack.
PostPosted: January 20, 2009, 8:47 pm
Some more pictures
File comment: New widened rack mount
File comment: My original rack housing, the stock rack and my modified rack.
File comment: The new and old rack housing compared. The new housing is an inch longer.
PostPosted: January 20, 2009, 8:53 pm
The Merkur diff mounted so I can take measurements.
PostPosted: January 20, 2009, 9:46 pm
Mark,
Aren't you using the stock Merkur Half-shafts? If not, why not? Don't they not work with the Haynes Roadster?
p.s.
Glad you got the steering rack sorted out.
Looking good!
-Indy Joe
PostPosted: January 21, 2009, 7:54 am
I'll have to modify them. If you build the a-arms to book, you would need to cut 10mm out of the Sierra half shafts. They did give plans for a-arms that are 10mm longer so you don't have to cut the half shafts. I don't like the look of wide fenders, so I didn't want to add to the rear width.
I used the Merkur parts, not Sierra parts. The Merkur has a wider differential and uses Lubro joints that bolt on both sides. The Sierra has regular CV joints and the one side slides into the differential. I wasn't sure what this meant for my measurements so I had to wait till I had it all together and could measure. The drivers side half shaft is 30mm to long and the passenger side is 20 mm to long. The extra width in the differential is on the drivers side. I'm not sure how much should be taken out until I talk to the drive line shop. I don't know how much preload should be in the Lubro joints.
PostPosted: January 25, 2009, 6:02 pm
I got the steering back together and am in the process of pulling the engine. I have to take the transmission down to the driveline shop this week to try and match the slip yoke.
File comment: There is now plenty of clearance between the engine and the steering universal joint.
File comment: Preping to pull the engine, the new wider rack is in place.
