MYTF's Haynes V6 RX-7 build
- MYTF
- Building: Gibbs Roadster
Hello from Pollock Pines, California.
I wanted to introduce myself and give a quick rundown on my build so far.
I haven't done a lot in this field before (considering my age) but a quick run through would include; rebuilding a couple V8's, buying and fixing a "59" sprite with the engine in pieces, took two wrecked Fiaros and welded them together to get one, assorted work on various Fiestas. I also have most of the tools required to build a car and have always liked the Lotus philosophy and cars.
I started my build the first of the year but am working out of town and things are progressing slowly.
- MYTF
More Pic's
I'm following the (new) book for as much as possible just changing a few things to make it fit the drive train and me. the tunnel has been moved to the right and narrowed, I am raising the rear 1" with the use of 1x2 tubing and the rear is redesigned to fit the various pickups.
killernoodle
Re: MYTF's Haynes V6 RX-7 build
Nice, making good progress I see.
- MYTF
Thanks I have actually gotten a little farther but things have slowed down working on the rear. At work found two hood supports from an old dozer with a nice radius that I will use for the corners.
- mr.peabody.d
- Locostering Information Liaison
Welcome Aboard.....your post has been stickied adn should be easier to find and for others to View.
I'll keep an eye out for you!
To err is human...
I am more human than most.
To err is human...
gaarie
- Building: D18A1
Ha, I used to live in Pollock. I've moved down the hill to Sacramento now. Looking forward to seeing your progress!
- MYTF
I'm going to try to finish up the rear today and move on to the tunnel. I have held off on buying my engine till I can install and start it within 30 days as it will be from a wrecking yard and I want the option of returning it. I will try to get some more pictures ported later today.
- Blackbird
- Weight watcher
- Building: R1 powered Locost
- Contact:
Okay, I guess it must be me that points out the obvious - RX7s are rotary powered, not V6
Which V6 are you dropping in there?
Moti
Moti
- MYTF
At this time i am looking to mate a mazda KD v6 to the RX-7 transmission like JOYFUL NOISE RACING did. The rotary Had sat rusting away to long before I bought the car for $100 and as I have no experience with the engine. I decided to go with something more conventional.
- Blackbird
- Weight watcher
- Contact:
Very nice attention to a minor design detail with the upper rear tube
It does curve down slightly yet most folks build it straight.
I intend to curve it down the same way.
Moti
Moti
- MYTF
Thank you yes I actually have the sides curving up to the center of the wheel then down slightly to the rear. I also raised the seat bulkhead by using a 1X2 at the top.
- Blackbird
- Weight watcher
- Contact:
Yes, and to get the full effect you'll need the curves in front of the wheel made out of a round tube and a bit larger than the fender
That's the part that I got in currently (I have not build anything behind the rear bulkhead yet).
Moti
Moti
- MYTF
Yes I intend to use 1" round tubing in front and have the same for the cockpit sills.
mconley3
excellent, another roadster build. Welcome aboard.
Mark
Mark
Mark Conley
Build Log: viewtopic.php?f=35&t=5947
- MYTF
Thanks, I've never been one to talk online (just like to lurk) but you guys have inspired me. I have to make a trip down the hill and pickup some 1/8" steel today as I dug out what I was going to use and found it was 3/16" and 1/4" which seems to thick for all the brackets and plates. Any thoughts?
