As there was nothing I could do about the windshield I decided to carry on with some of the other jobs on my list:
Finish the exhaust - 1 turndown to direct the gas away from the rear arch and a touch of high temp paint
Mirrors that I got from ebay last year some time. I had to use some cardboard for packing to get the clamping load right for my thickness of scuttle (I guess it is not the same as the bike the mirrors were designed for)
I finally found the red LED strips that I have been looking for to use as a third brake light. (Princess Auto keeps these lights behind the counter as they have a habit of walking off. I should have asked the first time I went looking for them)
I also added the license plate lights, also from Princess Auto
Finally I measured the cars corner weights with some scales I borrowed from work.
My first weights with me in the car were:
FL - 351
FR - 318
RL - 434
RR - 397
Total - 1500lbs
After a bit of fiddling I managed to get the left right split more even
343
326
440
392
These figures were very similar to Keiths example in his book, his book also stated that diagonals are more important than left right splits. In then took me several hours to get back to where I started.
Final weights
351
316
434
400
One of the many projects I have at home is finishing the basement, so my books are all packed away. Is using the diagonals for the baseline correct? I don't remember this from before, but Keith's car got good write ups when it was in a magazine.
Another oddity I found when playing with the front spring perches was that as I increased the ride height the corner weight went up - isn't this the wrong way round? Mind you I also found that if I decreased the ride height the corner weight went up Not sure what this means other than I seemed to have set the car up in a sweet spot by pure luck.
I also went to a wreckers yard and found that an older Toyota Tercel has a similar MC to the Miata but 3/4 so slightly smaller. However I found a couple of other posts here from people using the Miata MC so I figure I will have one more go using the standard MC
