Thanks for the photos regarding the clutch guys. I'm deinitely going to do something of a similar nature, just haven't gotten there yet. I've decided to tackle the exhaust next. Will use the stock manifolds for now, exiting to a 2.5" tube using a Flowmaster Resonator and Hushpower II muffler. The only thing I don't like about it is the cost, which is why I haven't progressed beyond the planning stage. Maybe I'll pull the trigger and visit Summit.com tomorrow. In the meantime, I've been closing off some loose ends:
Finally found some 90 degree bends in 1" tube that I could use. It's from an old swing set. I found lots in my travels (shopping cars, lawn mower handles, etc.) just nothing readily available:
Also bought some 16 gauge and cut and partially welded in a rear firewall. The bottom is still flapping around and not tight to the bar:
Found the throttle cable in a pile of junk, thought I'd lost that one, so I built a brackeat. It looks a little rough, not really thrilled with how the welds turned out, but it will work:
Finished up the LCA brackeats in the front:
Built a battery box, installed the lower seatbelt tabs, bought the wrong size battary, by a long shot, mounted the rad with rubber mounts etc.:
Struggling away on the wiring, might lose that battle, nothing some cash and a mechanic won't be able to solve though. I did manage to get the door buzzer working, very usefull indeed in one of these cars, the hazard lights, and the front signals. So a bit of progress. Hoping to get her sandblasted and painted on of these days, getting tired of the brown.
