Ewcarb wrote:
That escalated quickly JD
Did, didn't it?
I think I am sufficiently recovered to write about it all now. Maybe...
So, my long-time racin' buddy James ("Earl"), who is now technically my son-in-law, having married the HamDip, worked at a Ford Dealership (two of 'em actually) for years. He built Ford race cars, worked on Fords at the dealership, autocrossed modified Mustangs, etc. He now works at a shop that sells hot-rod parts for Mustangs. In other words, he knows a lot about Fords.
I have another buddy who isn't a mechanic but is a life-long gearhead. Rob is his name. He's a Mustang guy to the core. He's built several street machines and a few autocross cars that were killers. His current ride is a supercharged Fox body Mustang. In other words, he knows a lot about Fords.
Welllll.... Rob said I should use 24 lb/hr injectors in the stroker engine. James said the 19 lb/hr units I had were sufficient, not to change. I discussed it with them off and on for about a week. Rob pointed out that I had added 10% or so to the volume of air displaced by the pistons/cylinders, etc and that I should up the flow rate to keep the motor from going too lean at high RPM. James said the MAF and the new 'puter could compensate. Then James said if I was worried about it, I could run the car a few times and pull the plugs to look for bits of metal on them. Metal from the aluminum pistons...
I put the 24lb injectors in.
On my first run, within a few hundred yards of the start, something wasn't right. By the end of the run something was very wrong. When I slowed down after the lights, the car was barely running. Pulled into my grid spot and shut it off. Yup, flooded, fouled plugs, etc. It wouldn't re-start. And, of course, I had left the 19lb injectors at home...
I told James about the injectors. He was P*ssed... Guess deservedly so... I haven't talked with Rob about it. I'm sure he meant well... I may bake him a moose-turd pie...
It was Wednesday before I unloaded the trailer. If I had looked at the car Sunday night, I think I would have beat it into scrap metal with a baseball bat.
Ohhhh Kayyyyy...... Let's try this AGAIN...
Peace, Love and "Never mind all that Peace N Love crap, I'm P*ssed Off Too"-
JD, father of
Quinn, Son of a...
Build LogQuinn the Slotus:Ford 302 Powered, Mallock-Inspired, Tube Frame, Hillclimb Special "Gonzo and friends: Last night must have been quite a night. Camelot moments, mechanical marvels, Rustoleum launches, flying squirrels, fru-fru tea cuppers, V8 envy, Ensure catch cans -- and it wasn't even a full moon." -- SeattleTom
