*Lyndon Johnson voice*
Mah fellow Slotus Fans... Ah come to yew tonight with a heavy heart...
*Enough o' that, back to what passes for normal around here*
So here we go with a half a race report! It was a great half of a race. Right up to the point where the engine blew, things were wonderful...
Last time we talked, I had come from the Steeda event with some muchly improved handling thanks to the front sway bar. James and I had a plan in mind where at the Solo2 I would start off with the settings from Steeda and then try one setting stiffer on the sway bar, just to see if we'd get any "push" at that point. We were thinking it might guide us in going stiffer on the front springs, or how much to modify the mounts for the coilovers to give a stiffer wheel rate.
That plan was working fine as I made my three runs in the morning session. Car was handling good, turn in was great, no "lift throttle oversteer" at all and maybe just a touch of understeer on high speed corners. Perfect!
Then it was The HamDip's turn to drive. She made one run and the car seemed to be doing good, tires were coming up to temp and then the upper radiator hose sprung a leak. She came off course and we pushed the car off to the side. Repaired the hose in a few minutes, cranked it up and added coolant while it idled. Temp gauge was reading 190 when we started, dropped to 180, then a bit lower. HamDip went back to grid and made her second run. When she got back to grid, the guy running grid called me over. He'd had her shut it down because the engine was knocking. I asked her to fire it up, and sure 'nuff, knock-knock-knock. We pushed it back to the trailer. She was totally bummed out, felt like it was her fault, and was actually teary-eyed about it. Tried to explain it was "one of those things" but she didn't buy it. That bummed me out more than the engine, honestly...
So, the next adventure for our intrepid band o'crazies: Team Slotus builds an engine!!! Hang around, this oughta be EPIC!!!
(Background voice, Bubba saying, "What's epic mean, any ways???")
See y'all soon...
JD, father of
Quinn, Son of a...
Build LogQuinn the Slotus:Ford 302 Powered, Mallock-Inspired, Tube Frame, Hillclimb Special "Gonzo and friends: Last night must have been quite a night. Camelot moments, mechanical marvels, Rustoleum launches, flying squirrels, fru-fru tea cuppers, V8 envy, Ensure catch cans -- and it wasn't even a full moon." -- SeattleTom
