Had a tinker today. I pulled the motor and attached a transmission (without clutch) and bunged it all back in.
There's good clearance around the bell housing:
The shifter falls perfectly:
The motor is at a little up bubble with the stock transmission mount:
I'll check my Miata and see how the motor is mounted there, probably should be tilted back about 2-3 degrees, which I'll take care of when I modify the transmission mount. You can see how the transmission mount falls between the mount plate and a frame member. I can also fix this easily when I remake the mount:
I'll probably look for a UHMW puck or something as the motor mounts also need replacing.
Some stuff needs work/help. The IAC valve wants to be in the same space as a frame member:
because of this outlet:
Fix here is to cut off the outlets and drill/thread for 1/8" NPT straight barb fittings, which I'm ordering today.
The thermostat housing also wants to be in place of a frame member:
Fix here is to remove the thermostat housing by unbolting it from the head and making a new one to line up with the radiator and I'll use an inline thermostat with a temperature sender built in. Getting this bugger off means I'll have to pull the cam belt and cam gears so I'll take that opportunity to replace the belt.
Getting the motor in and out is a real fiddle because the motor mounts are just drilled:
I'll slot the frame mounts next time I take it out, which should make life a lot easier.
Heater hoses are not needed for this so I'll block off the heater outlet but keep the temperature sender:
Interesting how one of the IAC valve outlets feeds via the oil filter sandwich plate. I guess I'll just keep this of I can.
Trying to do the minimum I have to so I can fire up the motor.
Making progress finally ... and finding stuff I have to do. Next big jobs are to plumb the fuel and cooling systems.
Stuff to order to complete all this stuff:
Several 1/8" NPT aluminum barb fittings and bungs for the IAC and fuel tank.
Transmission mount puck/whatever.
Replacement motor mounts.
Clutch slave cylinder.
-Steve
