first350 wrote:
Looks like the front Coolant neck is kinda close to the chassis...if you have issues w/ clearance, think about doing a coolant re-route; the coolant gets routed out the back of the head, and it looks like you've got a lot more room back there...plus, it's better for cooling.
Quite right, there are a couple options including rerouting the cooling. The neck is just bolted to the head so making another neck is not too difficult also.
first350 wrote:
What size tubing is the frame?
1" square for most of it, the round stuff appears to be 3/4".
chetcpo wrote:
That looks really nice. Doesn't appear that the rear toe is adjustable or is there something I'm not seeing? A single master will work fine, but don't bother with adjustable prop valve, you'll need all of the available braking and more just for the rears.
That's true, rear toe is not adjustable with those control arms. Even if the lowers were able to do it, the uppers would also constrict it. It's on my list of 'improvements' after the car is running. Also, the inboard suspension pushrods all use right handed rod ends, so adjustment requires removal of one of the rod ends ... another 'improvement'.
Blackbird wrote:
Mazdaspeed motor mounts are a nice upgrade to the stockers.
They are made of 40% stiffer rubber compared to stock, so you get more accurate shifter action without much tradeoff on NVH.
Best of all, they're only $80 for the pair.
Awesome!
Thanks everyone ...
-Steve
