Miatav8,MstrASE,A&P,F wrote:
I know what you mean about needing the foam underneath. Not crazy about how the seat would react in an accident either..
well, I actually have direct experience with that exact style seat in a crash. in fact, its the seat that is now the drivers seat in the B-3.
back in the late 90s, I had an '87 camaro Z28 -with the Z28-starter-kit 190 horse 4bbl 305 and shift-kitted 700-R4 - which I did a bunch of autocrossing with. I had installed that 3-layer fiberglass dune buggy seat on a steel tube bracket I made, which held the seat by both the bottom (4 bolts) and about 12 inches up the back (2 bolts), and attached to the stock camaro adjustable seat tracks. I'd added the supprort to teh back because those fiberglass seats are a bit flexy in the flat areas. the seat was fastened to the steel tube with 3/8 inch hardware store, um, hardware, with some handmade steel doubler plates on the inside ( basically, a couple lengths of that standard zinc-plated predrilled mild steel bracket strapping you can get at about any hardware store).
yup, I aded an extra layer of foam under my butt. bot otherwise, it wasn't all that uncomfortable with the padding that came with the upholstery, and that car was my commuter ride as well. I had replaced the inertia-reel 3 point belts with manual adjusting 3 points belts to hold me in tighter during autocrosses. I dug that seat - the deep sides hold me nice and secure - and it was one of the few things I saved out of the Camaro after it got totalled.
yeah so, how it got totalled. not my finest moment. on a short side street with a "T" instersection, tree branches were partially obscuring a stop sign facing me, and duh, I blew through it, saw the sign as I went by it. ooops. BUT, at that time two teens in mom's camry came bombing thru the intersection, and T-boned the camaro on the passenger side rear wheel, hard enough to spin the car 180 degrees into a parked car and crack the camry's transmission housing in two (later the Policeman cited them for speeding).
the camaro was wiped. the rear axle stuck 8 inches farther out of the drivers side than passenger, the passenger rear corner was a folded mess, as was the drivers side rear corner from smashing into the parked car as I spun, and the posi in the differential was broken as well (as I found out doing One Last Burnout, just before the car was loaded onto the flatbed and hauled away to the boneyard).
the seat? didn't move. I had my 3 point cinched up tight and my legs and arms flailed a bit after the impact, but it held me right in place. the stock camaro seat tracks bent where they mounted to the floor, but my steel tube bracket, the fiberglass dune buggy seat, no issues.
Now, I know that tis is only one sample in the database, and anecdotal hearsay as well, so here's the grain of salt you should take it with, and I'm a rock climber who commutes 100 miles a day by motorcycle so and raced alky karts for a little while so my personal level of risk aversion may be seen to be insufficient, BUT...
I've crashed in that kind of seat, and it worked out fine, for me, and the idea of using two of those seats in the B-3 didn't/doesn't give me pause. bolt 'em in strudy with appropriate support, belt yourself in tight, and have at it!
YRMV, and the like...
