It is currently July 5, 2020, 5:28 am
Post new topic Reply to topic  [ 646 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 44  Next
PostPosted: April 25, 2013, 12:27 pm
March 12, 2013
Trimmed the 'back' chunk of engine casting off of the VFR engine so I could drop it in between my frame rails.. This is the portion of engine where the VFR's swing arm pivot was, so it was a useless chunk anyway.. Set the 149 lb. monster down into it's new home.. It is a tight fit on all sides.. biggest concerns are having the driveshaft (bike's countershaft) sit high enough to clear the Miata rack.. it will clear by about 1/4"... Also fitment issues with VFR water pump clearing steering rack.. it clears.. all issues clear so far, but most by less than 1/2"... these tolerances are so much more difficult to work with than the old 50's street rod stuff I'm used to working with :shock:
another shot as it will sit in car seen from front of car.jpg [ 158.7 KiB | Viewed 3771 times ]
PostPosted: April 25, 2013, 1:05 pm
SPRING 2012
With the engine roughly in place, I could start solving fitment issues and dealing with the 793 details needed to move forward..
Changing over from the bike's hydraulic clutch (cast into the countershaft cover), do a cable clutch was a challenge- the arrows show where the clutch rod goes through the motor; and how tight clearance was at the pivot at the top of the clutch rod.. Although the 2 pics I have of this aren't great, you can see where I made a long arm that pivots just under the countershaft flange.. it's impossible to see, but there is yet another pivot up under the arm/anchor that allow the long black arm and clutch rod contact point to travel in different arcs/angles.. Too tedious and make-specific to explain, but it took me a few days of head scratching to solve this one...
Also, found a somewhat recent pic of the T5 between the seats.. the angle makes the driveshaft flange look closer to the driver's seat than it it (in reality there's at least 5/16" in there! :lol: ). For reasons stated the T5 has since been pulled..
**btw- the 3-legged spider looking thing will be the engine side anchor point for the morse shifter cable..
PostPosted: April 25, 2013, 3:59 pm
Out with the old, in with the new..
The Miata diff was just too steep for freeway use at 3.9, so out it came.. In it's place went a Ford 7.5 IRS from an early 90s T-bird... my donor 7.5 came with 3.73 gears, so I swapped them out for a 2.73 R&P.. I'm just hopefull I didn't go too far the other way.. It took a lot of trimming to fit the pumpkin in the narrowed subframe, but it works.. Pulling the T5 took about 70 lbs out of the car, while swapping the little Miata diff out for the comparatively big 7.5 brought at least 20 lbs back in... Ideally I'm minus 50 lbs or so for having done this.. (looking for the silver lining here :roll: )
7.5 diff squeezed into miata clip narrowed 9.5 inches.jpg [ 177.47 KiB | Viewed 3752 times ]
PostPosted: April 25, 2013, 5:53 pm
Spring/ Summer 2012
Motor mounts completed means fabbing exhaust.. this is a pretty low-buck approach: I bought some swap-meet headers with 1.5" primaries and cut them up for my needs.. they went together pretty nicely all considered.. it was tough to match lengths, but I finally ended up with all 4 at 28.5", which may seem long, but I tuned them for torque.. The secondary pipe is 1.75".. maybe overkill on size- don't know.. later I would add a 2nd inline 'flow through' type muffler to further quiet the car.. still tweaking on how I want it to sound.. VFRs have a unique rumble, and I don't want to lose it..
I included a pic of the VFR stock exhaust for comparison- note how long even Honda made the primaries- mmmmmm, torque :lol:
PostPosted: April 26, 2013, 11:48 am
MAY / JUNE 2012
Assembled shocks/coils (150# front and 125# rear).. / started cutting out N600 oem inner fenders-front sheet metal in prep for custom inner fenders and engine bay detailing.. had to change inner fenders for wider tires and wheels and to accomodate lowered stance. // took out so much Honda sheetmetal it looks like swiss cheese up front! // placed front coil barrels (pass throughs) and proceded from that as a reference point.. (not sure how tall they'll need to be yet- will cut down as ride height is set later) / split and re-arched a new trailer fender to act as new inner fender base.. / Went to Pomona swap meet and picked up a good 67 Camaro rear bumper to cut down later- also got more POR15 for the floors (it is THE BEST rust preventative coating- period!)
PostPosted: April 26, 2013, 11:56 am
More on the hack job..
PostPosted: April 26, 2013, 12:00 pm
Going from removing to replacing...
cut down trailer fender will become n600 inner fenders.jpg [ 186.27 KiB | Viewed 3702 times ]
PostPosted: April 26, 2013, 12:12 pm
JUNE 2012
Lots of progress over the next few months as I'm a teacher with summers off... These pics show a bit of the always time-consuming panel replacement/ reconstruction... To this day I'm surprised at the lack of rust on this car.. I really just got lucky.. however, I did find a bit in the driver's floorpan, so I cut it back and replaced the damaged section.. later on a came back and stiffened this area up with an OEM stamped rib..
PostPosted: April 26, 2013, 12:35 pm
JUNE 2012
More panel/nose work.. The interior shot shows the oem floor rib I was talking about... floor is also in POR15 with seam sealer where apropriate..
The engine bay shots have the inner fenders/metalwork about 1/2 done... It took a bit of trial and error to learn how wide the inner fenders had to be, and how to have them clear the VFR head, particularly on the driver's side where things get especially tight.. eventually it all fit..
PostPosted: April 26, 2013, 12:41 pm
JUNE 2012
The engine went in and out several times as I had clearance issues on all sides.. I smoothed the firewall and did a bunch of detail work at this stage (although I didn't go too crazy with the detailing; this is not intended to be a show car).. In the end I just want it to look nice and clean and still be DD functional..
overhead shot of engine in place to check clearances.jpg [ 193.8 KiB | Viewed 3697 times ]
engine with exhaust and mc and inner fender arches in place.jpg [ 207.86 KiB | Viewed 3697 times ]
PostPosted: April 26, 2013, 1:36 pm
Engine bay paint.. Some guys will work to make their firewall perfectly smooth and into a mirror finish- and I can appreciate all that hard work.. In my case though, I'm just trying to make this car's engine bay look tidy and clean, stopping short of ever needing a toothbrush detail to make it shine.. Having said that, I chose to paint it with a paint I love that you can find at Lowe's or Home Depot... It's Rustoleum "Hammer Finish." You can brush it on, and it's very forgiving if you have minor surface imperfections.. If I had shot this with a gloss it would have looked pretty bad, unless I was willing to spend the time to really smooth it out.. The hammer finish paint looks pretty good in my opinion, and as I still have a bit of welding/finishing to do under the hood, touch op is a breeze. Some will not like it I'm sure, but I'm not building this car for them anyway :wink:
PostPosted: April 26, 2013, 1:51 pm
JULY 2012
Even with it's stock engine, this is a buzzy, noisy car.. To combat this, I did a couple of different things.. Instead of Dynamat or Lizardskin (two great products I can't justify paying for), I went with a low-buck appoach to each..
With all of the modding/welding I've done to this car's sheet metal, I've gone over the entire floor with POR15.. I've used it for years and love it. Money very well spent from my experience..
I read quite a bit on Lizardskin over on the H.A.M.B. forum and found many guys were mixing their own, so I thought I'd give it a try-- If I don't like it or it doesn't work I can always chip it out later.. You can read up on it and try for yourself- I don't have enough time in the car with it to tell one way or the other yet (and I still have too many gaping holes and uncovered panels bouncing sound around in my car).
The Peel N Seal is found at Lowe's, and at best it might be called the poor man's Dynamat... I put it in on a hot day (helpful) and I have not experienced the smell that others complain about... again, I'm taking the try it and see approach.. I think I 'm pretty safe having it stick well to the floor (others have said it does not stick well to verticle surfaces). Time and trial and error will tell on both.. ideally somewhere around late 2013/ early 2014 I'll know more about how these work out as my car will be driven more by then..
Threw in a pic of the ealy paddle shifter pivot/design.. still using this setup although cleaned up a bit now..
PostPosted: April 26, 2013, 9:27 pm
Wow! This is such an incredible build. Great info and pictures!
-Keith
PostPosted: April 29, 2013, 12:56 pm
July 10-17 / 20012
Closed up firewall and finished all undercoating / Finished exhaust engine to diff / trimmed pass side steering rack for boot fitment issue / Final install of brake lines, adjustable proportioning valve, line lock, and master cylinder / Finished interior floor w/ POR15 and 2 coats of Henry's Roof Sealant (added microspheres) / covered floor with Peel n Seal- 2 layers at firewall and front floorpan and 1 layer under front seats and rear of car / fabbed seatbelt mounts (front only).. / modded all 3 OEM N600 pedals as needed to work with new/ altered geometry / finished paddle shifter cable 'spider' bracket at engine (this took 3 attempts to get the correct angle for the cable.. / fabbed paddle shifter at column / cleaned front and rear window flanges and painted w/ POR15..
July 18-21, 2012
Went back ant had to cut slots into firewall where clutch and throttle cable go through so a cable can be changed/serviced later.. / painted all small enine mount bits / finished clutch linkage arm / Fitted pedals for install height.. For grins swapped motor #2's instrument cluster into the VFR... very surprised to learn this motor only has 17,000 miles on it!! :D I knew it was clean from having it opened, but I had no idea it would only have 1/3 the miles of my bike... hoping it runs well- if so, it is definately the 1st choice motor to use for this car.. / sealed up engine #2 (had the covers off of both sides) and preparing it for 'final' install to run it (I've had it in and out of the car at least a dozen times for fitment)..
7-20/21, 2012
Stripped VFR completely.. I didn't want to do this (as motor #2 looks so good), but I needed the bike's harness, starter, and some other odds and ends... Once it's all parted out I will have all that my N600 project needs, and although selling/shipping stuff is a hassle, I'll eventually get all $$ back that I spent on the VFR originally..
7-21-2012
Installed motor #2 for final time.. Installed driveline.. Finished fabbing clutch linkage..
PostPosted: April 29, 2013, 4:05 pm
JULY 25-27, 2012
Mounted radiators and started plumbing them.. No small affair placing these radiators.. there is very little room to fit any type of radiator (I wanted to use just one larger radiator but short of having a custom unit (like from Griffin), I'm going to try and use the bike's own radiators- it will just require some creative mounting and a shoe horn- (will need to switch VFR fan over to the bike's 'other' radiator) / Learned the only logical space for the oil cooler is down low in the driver's front engine bay pocket to keep it in the airstream.. / eliminated the VFR PAIR system and the intake flapper- capped all vacuum lines and eliminated all smog..
7-28, 2012
Mounted and plumbed oil cooler into pocket.. still need a few rubber 90 degree bends for the radiator plumbing.. started to fav a mount for the right bank coils... Seems I'm about down to fuel and electrical to make it start..
