OK, back to transfering . . .
03-18-2013
LCA progress
I got the first of four A-Arms done this last week, a LCA. It came out of the jig pretty nicely, only about 1/64" from perfect, if I can get the other LCA this close I am good to go. The lowers are made from 3/4" extra heavy tube, which is the same as most aftermarket off-road pieces for full size trucks. The outboard end of the LCA is tapped for a 1/2 rod end and set at 10 degree of tip to match the KPI angle. I figure that the Lower Control Arms is one of those places I don't want to cut any corners on as far as strength goes. I'll sacrifice a bit of weight for stout. They are going to be exposed and flying down the road at 70 mph 6 inches from the ground. . .
There are some brake parts and spindles in the garage now as well, along with a bunch of "maybe" stuff, like e-brake handle, brake master cylinder (boosted), seat belts etc. The poor donor is looking kinda ratty now, and will get hauled off soon. I just need a few more parts from the front suspension.
I am going to try and use the rear spindles from the donor as front spindles. I'll need to fabricate knuckles to bolt the spindles on, but I think I can do that.
Anyway, here are a couple shots of the lone LCA that I completed.
TALON §
__________________
Dang, those pictures are bad. Sorry.I am using Spitfire bushings for the lower/inner points.
03-22-2013
Knuckle
I have been working on converting the rear stub-axles I have to be used as front knuckles/spindles. Here's what I came up with. I had originally thought to use spindles/knuckles from a rear wheel drive vehicle, but Jack McCornack mentioned that he was going to use stub axles and build the knuckles, so I am giving that a go. (cheaper too, I had the stubs on the donor and would have had to find/buy the others.)
These are build from a piece on 3x1 thin wall tube, with a 1.5 inch hole in one side for the back of the stub axle. the 4 mounting bolt holes are reinforces with pieces of tube tacked inside. The "kingpin" angle is 10 degrees. The angle is made from a piece of 3/4 square thin-wall tube, plated on both sides and capped. the ends of the 3x1 are capped with pieces of 3/4 square tube. 13 pieces of steel altogether. The weight is less than it looks, as it is completely hollow.
The two threaded bungs aren't welded on yet, but should be tonight, then it is on to the adjustable upper arms. Once that is done, I'll have a uni-roller! The other side should be a lot quicker, as I have the jigs done and all the head-scratching out of the way.
TALON §
