It is currently March 29, 2020, 6:09 pm
Post new topic Reply to topic  [ 304 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 21  Next
 Post subject: Re: Too Busy's Mk I Mini
PostPosted: September 13, 2014, 7:31 am
Briggs - I might as well work on the Mini. The R1 is dead in the water until I hear back from SCDMV. I have a ready to drive car just sitting in the garage. The Mini project takes my mind off being pissed at the DMV
Bob, Minis are popular over here. It's a same that more of them didn't make it to the states, but in their day, they didn't stand a chance against the desire for a big gas guzzling V8.
I've been looking at replacement panels. Looks like anything I buy will have to come from a Mini specialist importer. There are 2 or 3 good ones and a handful of not so good.
Waiting on a shipping quote from New York, found one of the specialists with great prices on Heritage panels.
One more cup of coffee, then time to get dirty.
PostPosted: September 13, 2014, 8:13 am
This outfit are good for panels http://www.minispares.com/shop/classic/ ... .aspx?0307
If you want them crated and sent just ask, I am sure I could find a reasonably priced carrier.
Bob
PostPosted: September 13, 2014, 7:43 pm
Today's work in the garage.
I spent the first half of the day getting the subframes out. Dropping the front took a little less than 2 hours. Only 8 bolts holding it in, but like so many other items, it fought me every step of the way. A little WD40 and some heat from the propane torch got them to cooperate.
I used the engine crane to get it up off the subframe, then lowered it onto jack stands.
Then under the car to get the tabs off the suspension pipes, battery cable and fuel line.
Put the rear end up on jack stands and pulled the 8 bolts out of the rear mounts. Loosen the brake line, remove the hydro lines, and battery cable.
It's out
Tis car doesn't need a mechanic, it needs an oncologist. Serious case of cancer that would have been terminal with a couple more years of neglect.
Here's the ugly part at the back. Removed the companion box, the inner close panel, and cut away a rusty piece of the back seat pan.
It's finally time to start working on the front floor pan.
I cut away the rest of the pan and part of the toe board. Cut away the front part of the inner sill while I was at it.
Time to offer up the pan for final fitment
Clamped the brake to the engine hoist to bend the angles.
And used clecos to old it in place.
All in all not too bad a fit. I'll tack it in tomorrow and make the toe board reinforcement.
Pretty happy with what I've done so far.
PostPosted: September 13, 2014, 9:51 pm
1) I ran into Dyrk of Classic Motor Works today at Road America....we live only a couple of miles apart but we bumped into each other 1000 miles from home. I asked him about fenders and body parts and he says that he has them in stock.
2) Check out the classic mini front clip for sale here http://www.kijiji.ca/v-auto-body-parts/ ... nFlag=true. It is close to my house, if you want I can check it out for you and get more info and more pictures. Apparently he'll take less for it.
Bill
Bill H
Winnipeg, MB, Canada
PostPosted: September 13, 2014, 10:45 pm
That looks like most of a Mk3 front clip. Won't attach to my car very easily.
I'm ready for a couple of Tylenol and a good night's sleep. Knees are achy from all the up and down and crawlin around
PostPosted: September 14, 2014, 8:09 am
What??? You're out of duct tape and Gorilla glue???? :rofl:
PostPosted: September 14, 2014, 9:39 am
I can see why you need them. That's a lot of work done very quickly. Your floor pan looks very good too.
PostPosted: September 14, 2014, 2:17 pm
Man, really cool stuff so far!
Ford 5.0 into an M3
mikaelvroom.com
PostPosted: September 14, 2014, 7:26 pm
Spent a few hours in the garage after church today. more working, not so much picture taking.
A little final trimming and tack welded in place.
the brown around the edge is a light coat of paint to make final trimming easier.
A little measuring and heres a patch for the rotten part of the toe kick reinforcement.
Offering it up to see if it will work.
Then I put the cell phone away while I concentrated on making a patch for the inner fender. I'm overlapping the existing inner fender by about 1/2 inch at the top. I'll weld it both inside and out.
Also made a new front inner sill while I was at it.
It's about 75% welded. Using my 220 volt flux cored mig on the next to lowest setting with .030 wire. It's doing OK, but I should head out and pick up a bottle of gas and do it with shield gas instead of flux core. I could run a little cooler and have it smoother.
PostPosted: September 14, 2014, 7:40 pm
I was going to ask if you were cutting the panels flush to the edge or with some overlap - I suppose if you're welding the overlap inside and out you'll minimize the potential for moisture to get trapped in the overlap and undo all of your rust removal.
Ford 5.0 into an M3
mikaelvroom.com
PostPosted: September 14, 2014, 8:34 pm
I decided to overlap cause I kept blowing tough with a butt weld. I couldn't get a heat setting where I could squeeze the trigger for more than a split second.
I'm going to button this beast up as water tight as I can get it. Then clean, prime, paint, and undercoat. I hope to get a few years before the tin worm reappears.
PostPosted: September 14, 2014, 8:36 pm
Those come later JD. Right now it's mig wire and band aids
PostPosted: September 15, 2014, 9:27 am
I overlapped too because my tack welds are great and my butt welds are not so great. I used seam sealer from the local auto body supply shop to close both sides. I've got almost ten years of driving without any rust reappearing but my Mini lives in a heated garage and doesn't go out in the winter. I do drive it to work regularly during the rest of the year.
Great work on the patch panels! As fast as you are it won't be two years, maybe only a few months.
Duct tape is too wimpy. Get Gorilla tape.
PostPosted: September 15, 2014, 11:01 am
It feels like I'm moving in slow motion. The car has resisted so many times already. Rusted bolts, captive nuts that aren't secured, rusty / rounded bolt heads, parts brazed instead of welded or leaded...
The patch panel process is slow and labor intensive. The only good news is I'm getting just a little bit better at fitting stuff by eye or with a couple of reference lines from a sharpie marker. Practicing on parts for TETANUS and the R1 project were a good primer leading up to this.
Next Saturday I HOPE to fit the other front pan... we shall see.
PostPosted: September 15, 2014, 9:59 pm
Looks good. I'm following this one closely. I always thought with my new found rudimentary metalworking skills I've acquired building the Locost, I would tackle replacing floors and other simple flat surfaces on a rusty vintage car. Minis are on the long list of potential cars I always have an eye out for locally. Keep updating the facebook page. I may not comment much, but I'm enjoying the updates when I can't get on locostusa.com.
