It is currently November 18, 2018, 2:40 am
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: May 23, 2018, 2:20 pm
I've made some good progress in the last couple months, so time for an update. First off, I made a bracket to mount the Speedway Motors radiator overflow tank to the radiator, and then made brackets to secure the radiator:
PostPosted: May 23, 2018, 2:21 pm
Next, cardboard and wood templates made for the sheet metal body panels:
Driver's side door skin in sheet metal:
PostPosted: May 23, 2018, 2:24 pm
Driver's quarter panel sheet metal with aftermarket locking fuel filler door for a Dodge Ram:
PostPosted: May 23, 2018, 2:25 pm
Rear deck plate with rear speakers, and subwoofer box under it. Still needs to be covered in black carpet or vinyl:
PostPosted: May 23, 2018, 2:26 pm
No room behind the dash (plus, I wanted to keep the dash uncluttered) so the front speakers are mounted on top of the transmission tunnel:
PostPosted: May 25, 2018, 5:38 pm
Got the outside door handles mounted:
Got the firewall cut out with the holes for the brake booster, clutch master, steering shaft, throttle cable and wiring harness pass through:
PostPosted: May 25, 2018, 5:39 pm
Made a bracket that bolts to the valve cover to secure the routing of the unmodified Miata throttle cable:
PostPosted: May 26, 2018, 6:37 pm
Oh dang. Most of the photos previous to a year ago have disappeared. Perhaps they were linked to some outside source rather than properly planted* in the forum?
*No, I don't speak geek very well. How did you know?
PostPosted: May 26, 2018, 11:47 pm
That's likely a result of the Photobucket fiasco, before I started attaching my photos directly. I'll need to go back and attach the earlier photos directly at some point.
PostPosted: August 11, 2018, 8:34 pm
A few more updates to share. I started running the brake and clutch lines and got the floor pans and transmission tunnel cover done. I also got the front seat belts installed. I then covered the dash panel in black vinyl and added an aluminum bezel around the gauges. You can see by the reflection that I installed a piece of plexiglass behind the dash panel to protect the gauges.
PostPosted: August 12, 2018, 2:53 pm
NICE! Very Nice, I must say!!! :thmbsup:
Users browsing this forum: Bing [Bot] and 3 guests
