This weekend's update PART TWO:
Got the radiator mounted and plumbed up. I had some technical difficulty when it came to conceptualizing routing the tranny cooler lines... there are a few extra bends then there should have been(there is an S curve in it).
I filled it with coolant, fired it up, and it ran like a champ. Both cooling fans turned on at 212 and turned off at 190.
Then I worked on cleaning up the wiring a bit more. Still looks ugly, but at least they're protected and semi secured now.
I mounted one of the fuse boxes under the seat, but it turns out that its a half an inch too tall, so Ill have to re-mount it somewhere else next time im up there.
I also got the cutting brake mounted and the rear brake lines run. I need to buy a tee to plumb the front line into the cutting brake.
It was at this point that I noticed that the brake pedal was too far to the right... So I had to cut one of the steering column mounts and move the pedal over, now I have enough room for a gas pedal.
Ill try to get the brakes done and mount the shifter next weekend so I can test drive it(move it front and back a little).
