Time for this weekend's update. Got a lot done and ran into some issues.
Got the following done with no issues:
-Power Steering Hoses made and installed
-Installed & wired in a horn
-Mounted the rear turn signals
-Wired in turn signals
-Connected water temp sensor to gauge
I went to wire in a fan switch and didn't know if the white or black wire was hot...it took 25-30min of idling to get it up to 212F, then 1 minute later, back down to 178F. And... the black is the hot wire(great logic GM...).
I tried to get the tach to work(Koso RX-2n) and I couldn't get it to read. I had my uncle re-make the tach signal wire so that it could be longer(made exactly the same except length). I tried wrapping the lead around the spark plug wire near the plug, near the coil, taping it near the coil... everything the instructions told me to and nothing...
Any one have any suggestions? I'm going to call Koso tomorrow.
I also started mocking up the body panels in cardboard to use as templates next weekend.
Ive got some wheels on order, so hopefully i can get tires mounted and installed this week so I can get them on prior to starting the body panels.
