Had a GREAT meeting with the service manager at the Harley dealership!!!
("This" [u]WILL[u] work!)
The manager spent a lot of time with me and totally understood my application for the HD transmission too! (He was genuinely excited about what I was creating.)
He brought me in back to take a look at some clutches (He looked in his "trash bin" thinking he had a clutch in there he could give me, but someone before me took it... Oh well. I did get all the info I needed though!
He ran me through the different year differences (focusing on the input and output shafts, availability, use of a dry clutch and adapting them to chain sprockets).
He suggested that I search for a 5 speed transmission from a 1990 - 1999 softtail. They used a belt for both primary and final output drive and there were a lot of them made... Also, used ones should be available as many owners switched to the 6-speed transmission. He was right! I found a LOT of them on E bay and a few were as cheap as $250... Up to $500 for reconditioned and "almost new".
HD makes a conversion for the output for belt to sprocket.
To convert the clutch belt input, he totally agreed with me that I could easily remove the back steel belt pulley and starter gear (I'd shed off a lot of unneeded weight!) by "popping off the rivets" to remove it leaving the clutch basket. He felt the back of the clutch basket was way thick and that I might get away with just drilling and threading it to attach a chain ring to accept a MC chain application between my EV motor drive and the clutch. (I don't remember if the clutch basket or the steel pulley had the splines for the input shaft. (I think it's the steel pulley plate, which is fine, I can turn the plate on my lathe so that it becomes a smaller diameter "disc" to be machined to be the receiver for my MC chain ring.)
He also suggested that I use the same chain as the Kawasaki drive as the Harley chain is HUGE and I don't need the added strength or weight and... he felt that using the Kawasaki chain would make for a smoother running drive.
I went back on line to confirm the actual transmission gear ratios as most of the discussions on the different forums were about "final" ratios...
MiataV8: You had it right! The ratios you gave me were for the transmission and not final! (I wasn't sure which ratios you posted.)
I continued researching and found two great ratio calculators WITH a drop down menu that included '95 to '99 5 speed soft tails! This will help tremendously as I can use their "primary" ratios to calculate EV rpm to transmission input, AND then calculate output to rear wheel to get my final ratio to compare EV motor rpm and efficiency at different mph!
New replacement pads,steel plates and springs were $200 (He said I could get them cheaper on line, but I'd like to support his local business as I felt his help was "priceless"!
I also asked him about the weight of the transmission... He said 80lbs - 100lbs! (I just can't imagine that after looking at the transmissions on the bikes on display.) Since I didn't need the starter plate, he said I could machine the case to remove unneeded flanges etc which would drop the weight.
And... the belt drives on the '90 - '99 soft tails used dry clutches!
I couldn't ask for more great news than this!!!
The challenge of coupling my EV motor and the ICE to this "drive system" has been solved!
(Incredible sense of relief and reduction of stress here!)
I'm taking the "day off" from all of this and going to spend some "comfort time" with Tresa.
Thank you so much for all your help! (Especially YOU, Miatav8!!!)
signing off for a while... After I get my solar heaters built and installed, I'll re-install my wood mock up parts on my shop table and get back to working on the "fun stuff"!
Best,
Richard
