Short update: The city clerk of Beloit got back to a week ago. They have no records of it. She forwarded my request to their Chief of Police. I'm sure this is not top on his (her?) priority list so I'll give them another few days before I remind them I'm waiting for a reply.
On another front, I received the regulator. Unfortunately, it was poorly built and the rivets used for electrical connections were loose. When it worked at all, it put out a lot of volts. IT was also touchy when the frame of the regulator was torqued slightly. I checked everything to no avail. Time for another approach. I looked at getting the newer (relatively) 10SI alternators but couldn't find a low output (38 or 42Amp) version. So I decided to keep my original alternator and try a solid state regulator. 1960's batteries usually charged at around 15 volts. Higher than I'd like to run them. Modern cars run around 14 volts give or take for temperature conditions. I found one regulator spec'd for 14.2 Volts. So I ordered that. It should be here this week.
With a bit of studying of schematics, I figured out how the mechanical regulator was supposed to work. So not to be beaten and to prove I was the boss, I went back and bent a few contacts and got the mechanical relay functioning and regulating at 14Volts. Hooray! So while waiting for the solid-state version to show up, I put the cover back on the relay and screwed it down. I was about ready to call it a day, except....... That's when I found that the steel cover affected the magnetic field of the relays and the voltage set point was now set at a measly 13V. I removed the cover and it went back up to 14V.
The new 14.2V SS regulator is scheduled for delivery on Monday. Once verified, I will begin the dismantling process.
In the mean time, Turkey Day is over and I now have Christmas decorations to get out of storage and put up.
