I decided that the brackets should bolt to the frame so that I can remove them or alter their location later without cutting welds. The pedals don't travel quite parallel to each other, but from what I can tell, it won't be an issue. They are close enough that it doesn't seem obvious. I'll see how it is with the seat in place. I can't really move the clutch, the space is too tight, but the brake pedal could be moved a bit.
Once the paint dries, the clutch will go in and I can plumb everything up. You can see the clutch line poking out under the rail, covered with blue tape. The clutch pedal arm will have to be cut down a little to fit correctly, but otherwise everything is pretty good.
Funkatollah wrote:
These "little" jobs are always the hardest for me to take my time with. It's not that they aren't critical to success or any less important, it's that they don't seem to have the same impact as mounting whole suspension modules or getting an engine in.
I completely agree. I make myself go out in the garage at least three times during the week, even if it is just to stare at it for a half hour and think about what I want to do. The little tasks just don't have wow factor that the big ones did. I feel like I can taste the finish it is so close, but there are a million "little" jobs to go and I shouldn't rush them.
Next up: complete plumbing the brakes and bleed them out. Then I can finish up the e-brake linkage. Then I need to finish the fuel lines. Then I need to pull the engine out. And then I can rebuild all the sheetmetal I cut out. And then I can put the engine back in, and wire it all up. And then I can mount the seats and put the steering wheel in...I've got a ways to go
. Just keep chugging, every task complete is that much closer. I'm hoping to have it drive-able in some capacity by no later than early spring. Even if it doesn't have functional gauges and lights. I'm secretly hoping that by the beginning of April, it will be fully functional (lights and gauges) so that I can drive it to work when I want (I'm kind of hoping to near daily drive it to work). That will be the 1 year mark since tear-down. After that I can work on the pretty things at whatever pace pleases me.
