It is currently July 8, 2020, 7:37 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Micro Car Resto-Mod
PostPosted: December 19, 2016, 7:59 pm
Freed the engine from the bike today. It put up a good fight
Image20161219_154437 by Ben Modified, on Flickr
My Other Projects are here:
http://www.BenModified.com
PostPosted: December 21, 2016, 11:32 pm
Temporary bracing in place while fabricating crossmembers and engine mounts
Image20161221_173007_resized by Ben Modified, on Flickr
Image20161221_172930_resized by Ben Modified, on Flickr
Part 2 is on youTube:
https://www.youtube.com/watch?v=4UD0C1rUGvU
PostPosted: December 24, 2016, 7:20 pm
Progress on the Engine Mounts
Image20161224_165531_resized_1 by Ben Modified, on Flickr
Image20161224_165911_resized_1 by Ben Modified, on Flickr
Image20161224_165509_resized_1 by Ben Modified, on Flickr
Image20161224_165454_resized_1 by Ben Modified, on Flickr
Added a brace between the lower rear subframe and the rest of the chassis. I will cap off the ends later
Image20161224_165548_resized_1 by Ben Modified, on Flickr
Braced the Body for the rocker panel ectomy
Image20161223_165636_resized by Ben Modified, on Flickr
PostPosted: December 25, 2016, 7:57 pm
Started separating the body from the make-shift chassis. Also, found a stash of walnuts in both rocker panels
Image20161225_133057_resized by Ben Modified, on Flickr
Image20161225_132733_resized by Ben Modified, on Flickr
Image20161225_132724_resized by Ben Modified, on Flickr
PostPosted: December 26, 2016, 10:49 pm
The body is off
Image20161226_150940_resized by Ben Modified, on Flickr
One pair of cushman truckster to autobianchi wheel adaptors now available
Image20161226_160513_resized by Ben Modified, on Flickr
Fitting the body to the new chassis
url=https://flic.kr/p/QB6wMc]Image[/url]20161226_163827_resized by Ben Modified, on Flickr
PostPosted: December 27, 2016, 8:39 pm
Progress
Image20161227_085323_resized_2 by Ben Modified, on Flickr
Image20161227_092813_resized_2 by Ben Modified, on Flickr
PostPosted: December 28, 2016, 8:31 pm
Today I took the body off again to trim off the rest of the unnecessary sheet metal and cut out the inner rear wheel wells so that the tires would fit. Also notched the ends of the frame rails to match the body shape and provide needed tire clearance. Finished off the day by grinding off a ton of undercoating. What a mess!
Image20161228_160557_resized by Ben Modified, on Flickr
Image20161228_160613_resized by Ben Modified, on Flickr
My hubcaps from Summit/United Pacific came in yesterday. They are chrome plastic with an outer white edge for the white wall tire look. Made in Taiwan...but designed in Germany! Good quality/good price and they won't rust.
Image20161228_160517_resized by Ben Modified, on Flickr
Image20161228_161820_resized by Ben Modified, on Flickr
The tires fit the wheel opening very well and I am very happy with the body drop aesthetics.
PostPosted: January 3, 2017, 12:14 am
What a cool little car!! I thought it was a Vespa 400. Good luck!! Can't wait to see it finished. I am building an Isetta at the moment. Don't you own the Single Cab hot rod? If so, are your headlights on that thing mounted backwards? I've followed your videoa on youtube on the project and always wondered that. Great job on that as well!! Well, take care
PostPosted: January 5, 2017, 10:47 pm
Thanks! Yes, the single cab is mine. The headlights were in spring loaded indexed mounts but have since been swapped out.
Image20161129_151645 by Ben Modified, on Flickr
Is the isetta posted here?
PostPosted: January 6, 2017, 10:07 pm
Yes its on my profile!!
PostPosted: January 13, 2017, 10:28 pm
Started fabricating the upper strut mounts
Image20170112_162017_resized by Ben Modified, on Flickr
Sourcing parts for a short driveshaft with a slip joint to accommodate the rubber mounted engine
Image20170112_161727_resized by Ben Modified, on Flickr
The male and female yokes fit perfectly but unfortunately are never quite in-phase. Today I machined an alignment collar so that I can cut, rotate and weld the female yoke. Currently it is out of phase by 9 degrees which apparently will cause noise and vibration.
Image20170112_161708_resized by Ben Modified, on Flickr
PostPosted: January 14, 2017, 4:16 pm
The 1310 series rear yoke has the same bolt pattern as the Miata diff but the holes are drilled for 1/2" bolts and the Miata is drilled for 5/16" (8mm). Machined some inserts to take up the slack
Image20170114_094426_resized by Ben Modified, on Flickr
Image20170114_105541_resized by Ben Modified, on Flickr
PostPosted: January 17, 2017, 8:41 pm
More work on fitting the spicer 1310 series flange yoke to the Miata diff. The stock driveshaft has a male pilot bushing built in but the spicer is a female. This bushing will get sandwiched in between to serve as the pilot. It is machined down from 2" round bar stock.
Image20170117_151933_resized by Ben Modified, on Flickr
Image20170117_172443_resized by Ben Modified, on Flickr
Image20170117_172521_resized by Ben Modified, on Flickr
Image20170117_172532_resized by Ben Modified, on Flickr
PostPosted: January 18, 2017, 8:34 pm
Finished fitting the rear yoke
Image20170118_173012_resized by Ben Modified, on Flickr
Trimmed down the outside edge
Image20170118_180101_resized by Ben Modified, on Flickr
Image20170118_180431_resized by Ben Modified, on Flickr
Image20170118_181356_resized by Ben Modified, on Flickr
PostPosted: January 20, 2017, 8:31 pm
Progress on suspension. Made upper spring/shock mounts from 1/4" thick 6" wide flat bar. In the front, tubing comes up from the subframe to a brace that will bolt in place. It will be removable to extract the struts without separating ball joints and tie rods.
Image20170119_093043_resized by Ben Modified, on Flickr
Image20170119_094333_resized by Ben Modified, on Flickr
The brace will be clamped in place temporarily to determine proper ride height.
Once determined, a flange nut will be welded into the top of the trimmed off tube. Will also weld a plate over the 1 1/2" hole thru which the bolt will go.
Image20170120_093328_resized by Ben Modified, on Flickr
Image20170120_102302_resized by Ben Modified, on Flickr
Heated and bent the ends of the tubes to match the strut angle
Image20170120_123356_resized by Ben Modified, on Flickr
Started on the rear supports also. Mostly done, just need a couple of gussets.
Image20170120_171918_resized by Ben Modified, on Flickr
The supports are out from under the car. The front is on its wheels and the rear in on a floor jack waiting for the gussets.
Image20170120_124742_resized by Ben Modified, on Flickr
