It is currently August 11, 2020, 5:07 pm
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Micro Car Resto-Mod
PostPosted: February 7, 2017, 8:52 pm
After searching unsuccessfully for an R1 engine, I finally moved forward and installed the cbr600 engine instead. Plenty of leg room for the driver and a sufficient amount for the passenger.
Image20170206_152511_resized by Ben Modified, on Flickr
Image20170206_152535_resized by Ben Modified, on Flickr
Image20170206_152656_resized by Ben Modified, on Flickr
As soon as I got it into place I ran across this for sale.
Image20170207_140242_resized by Ben Modified, on Flickr
A well worn but good running 2001 Yamaha R1. 150hp (cbr was 100) with much better dimensions for the Autobianchi. It will allow more passenger room and has a much better output shaft placement and will also give me more ground clearance.
http://www.BenModified.com
PostPosted: February 11, 2017, 8:27 am
Thrilled to have Build-Threads.com profile my builds on their site!
http://www.build-threads.com/build-thre ... ed-videos/
PostPosted: March 24, 2017, 7:01 am
Motor is out of the R1. Very compact!
Image20170323_162434_resized by Ben Modified, on Flickr
PostPosted: March 24, 2017, 10:42 am
The compact nature of bike motors is amazing. To think that you can be sitting on 150 HP not that much bigger than the 3 HP Briggs and Stratton you screwed around with as a kid is boggling.
PostPosted: March 24, 2017, 6:12 pm
Made some progress mounting the R1 engine today
Image20170324_160647_resized by Ben Modified, on Flickr
PostPosted: March 25, 2017, 3:10 pm
The driveshaft is finished. The slip joint is to allow for the rubber mounted engine
Image20170325_101213_resized by Ben Modified, on Flickr
Image20170325_102254_resized by Ben Modified, on Flickr
PostPosted: March 27, 2017, 7:34 pm
Engine is properly positioned. Driveshaft is bolted in and engine mounts are coming together
Image20170327_170951_resized by Ben Modified, on Flickr
Image20170327_174837_resized by Ben Modified, on Flickr
PostPosted: March 27, 2017, 7:47 pm
Are the yokes slightly out of phase or is that just camera angle?
With no damping in the shaft you might feel some phase surge. If I were doing another BEC shaft drive I'd put in a guibo.
Good looking build!
PostPosted: March 27, 2017, 9:28 pm
Good looking build!
Must be the camera angle. I made sure that the shaft was perfect. I had considered a guibo to compensate for the rubber that is in the motorcycle rear wheel hub but could not find one to fit in the space available, instead, I rubber mounted the engine. On my suzuki reverse trike, the 1st gear engagement is harsh without it.
Thanks for the input!
PostPosted: March 28, 2017, 7:26 pm
Finished all the motor mounts
Image20170328_150534_resized by Ben Modified, on Flickr
Image20170328_150518_resized by Ben Modified, on Flickr
Image20170328_150502_resized by Ben Modified, on Flickr
Also cut up the original R1 header and started reconfiguring it to fit the car
Image20170328_175558_resized by Ben Modified, on Flickr
PostPosted: March 29, 2017, 7:08 pm
Part 6 is on YouTube
https://www.youtube.com/watch?v=gg5uhM6mWJw
PostPosted: March 29, 2017, 10:34 pm
I am a little bit concerned about your driveshaft. 1st, the angles look much more than a couple of degrees which is the ideal. You may get a bunch of vibration. 2nd, It appears that you have welded the spline on the yoke. The welding looks less than professional. Even if it was, I would be afraid of the long term reliability of the weld or the HAZ area. If you have already done your homework on this and know it will be OK, never mind. :cheers:
PostPosted: April 7, 2017, 9:16 pm
Got the header done
Image20170405_175118_resized by Ben Modified, on Flickr
Image20170405_181244_resized by Ben Modified, on Flickr
PostPosted: April 9, 2017, 10:04 pm
Part 7 is on YouTube
https://www.youtube.com/watch?v=O6t1FKe0fic
ImageThumbnail Raw by Ben Modified, on Flickr
PostPosted: April 11, 2017, 7:35 pm
Finished up the shifter and made up some brackets and bracing to install all of the Miata e-brake parts.
Image20170411_163146_resized by Ben Modified, on Flickr
Image20170411_164948_resized by Ben Modified, on Flickr
Image20170411_172843_resized by Ben Modified, on Flickr
Image20170411_093043_resized by Ben Modified, on Flickr
Image20170411_173954_resized by Ben Modified, on Flickr
http://BenModified.com
Users browsing this forum: No registered users and 33 guests
