It is currently February 21, 2019, 1:55 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Micro Car Resto-Mod
PostPosted: April 11, 2017, 7:51 pm
U joint needs a scatter shield?
PostPosted: April 16, 2017, 7:38 pm
Probably not, but will install one anyway!
Todays progress
Master cylinder is installed and the brakes are bled. The exhaust system is done. I used a dynomax vt muffler. It uses a spring loaded flap which increases back pressure at low rpm, very similar to the factory R1 header, and opens as rpm increases. Also reduces noise and droning at lower cruising rpm. I have heard that these mufflers sometimes rattle as the valve opens and closes but according to the manufacturer, it is brought on by a lopey idle, which the bike engine does not have. The car will look mostly stock but I think the the 3" exhaust may give it away!
Image20170416_144632_resized by Ben Modified, on Flickr
Image20170416_144618_resized by Ben Modified, on Flickr
Image20170416_114608_resized by Ben Modified, on Flickr
Image20170416_114238_resized by Ben Modified, on Flickr
Image20170416_113938_resized by Ben Modified, on Flickr
http://www.BenModified.com
PostPosted: April 26, 2017, 10:34 pm
Progress on the seat brackets and install
Image20170426_111724_resized by Ben Modified, on Flickr
Image20170426_112439_resized by Ben Modified, on Flickr
Image20170426_112730_resized by Ben Modified, on Flickr
Image20170426_122114_resized by Ben Modified, on Flickr
Image20170426_122410_resized by Ben Modified, on Flickr
PostPosted: April 27, 2017, 3:11 pm
Part 8 of the Build is here:
https://www.youtube.com/watch?v=uYu3uOHTLbI&t=25s
PostPosted: May 2, 2017, 10:17 am
Todays progress:
Extended the original Yamaha wiring harness and mounted the dash pod
Image20170501_172656_resized by Ben Modified, on Flickr
Image20170501_173902_resized by Ben Modified, on Flickr
Image20170502_172158_resized by Ben Modified, on Flickr
Image20170502_103251_resized by Ben Modified, on Flickr
PostPosted: May 3, 2017, 6:53 pm
Mounted the R1 electrical components under the drivers seat
Image20170503_160229_resized by Ben Modified, on Flickr
PostPosted: May 5, 2017, 4:48 am
Fabricated all of the seat belt mounts today
Image20170504_122517_resized by Ben Modified, on Flickr
Image20170504_122505_resized by Ben Modified, on Flickr
Image20170504_121043_resized by Ben Modified, on Flickr
PostPosted: May 9, 2017, 7:20 pm
I am going to use the original R1 motorcycle gas tank and mount it in the truck of the Autobianchi. I made the rear mount today along with more roll cage to body connections...complete with lightening holes.
Image20170509_160942_resized by Ben Modified, on Flickr
Image20170509_161002_resized by Ben Modified, on Flickr
Also used some exhaust tubing to start fabricating the floor. The tubing surround the rear section of the upper control arm. It is slotted to allow movement. The caps are for access to the control arm nut.
Image20170509_161116_resized by Ben Modified, on Flickr
These are just plumbing caps which I have machined down to fit.
Image20170509_161547_resized by Ben Modified, on Flickr[/IMG]
[img][img]https://c1.staticflickr.com/5/4165/34562942395_bc298819a3_b.jpg[/img]20170509_162200_resized by Ben Modified, on Flickr
PostPosted: May 10, 2017, 5:41 pm
Bike gas tank is going in to the car
Image20170510_103719_resized by Ben Modified, on Flickr
Image20170510_144128_resized by Ben Modified, on Flickr
PostPosted: May 10, 2017, 11:07 pm
Part 9 is on YouTube
https://www.youtube.com/watch?v=HiYIRXMrSDw&t=25s
PostPosted: June 8, 2017, 4:46 pm
Getting started on the radiator install. I am using copper tubing to route the coolant from the engine to the radiator which will be mounted up front. If all goes as planned, I should be able to mount the radiator with sufficient air flow and also mount a spare tire under the hood. I purchased two 10' lengths of 3/4" copper tubing and a variety of fittings. The R1 engine uses 1" diameter coolant hoses which will fit nicely over the copper tubing. The OD of the tubing fitting is very close to 1".
Image20170608_124322_resized by Ben Modified, on Flickr
The tubing comes in a couple of different wall thicknesses, I went with the thickest, the "L" variety.
Image20170608_124345_resized by Ben Modified, on Flickr
I have seen this tubing used on some street rods in the past and feel confident that it will work here as well. This will be my first attempt at sweating copper joints, so we'll see how it goes. Also picked up a propane torch and other tools necessary for the job. The tubing is very affordable but the fitting add up quickly. I hope to return several after the job is completed.
Besides 45 and 90 degree fittings, I also purchased some with wide threaded ends. I machined off a portion so as to duplicate the dimensions of the radiator inlet and outlet flanges. The fittings will be sweated on to each end of the tubing to give the rubber radiator hoses a proper attachment point.
Image20170608_124429_resized by Ben Modified, on Flickr
The machined piece is resting on the radiator to show the mirror image. The radiator in the photos is a used and abused one. I have a new one on hand when the time comes to install it for good.
Image20170608_124439_resized by Ben Modified, on Flickr
PostPosted: June 10, 2017, 2:21 pm
Progress on the radiator plumbing
Image20170610_090853_resized by Ben Modified, on Flickr
Image20170610_090922_resized by Ben Modified, on Flickr
Image20170610_085450_resized by Ben Modified, on Flickr
Temporarily zip tied in place
Image20170610_085509_resized by Ben Modified, on Flickr
PostPosted: June 11, 2017, 12:07 pm
Lower engine coolant outlet
Image20170611_071300_resized by Ben Modified, on Flickr
Connected with off the shelf Rubber Elbow
Image20170611_071332_resized by Ben Modified, on Flickr
View from underneath
Image20170611_100532_resized by Ben Modified, on Flickr
Snaking around the engine towards the front of the car
Image20170611_100509_resized by Ben Modified, on Flickr
Image20170611_100441_resized by Ben Modified, on Flickr
PostPosted: June 11, 2017, 7:35 pm
Wow! Thats quite the coolant run. :cheers:
Are there any concerns, regarding the OEM coolant line size, length and geometry of the coolant run, as to hydraulic line loss?
PostPosted: June 13, 2017, 7:25 pm
I am not overly concerned about it. It is a very small car, so that run is short. Stock Radiator at the stock elevation in regards to the engine. I did not use any more 90 degree bends than the bike had to begin with. Worst case, I would gut the insides of the stock pump (which is located inside the crankcase) and install an inline electric water pump (sbc etc) I have some experience with other remote mount rads and never had issues.
I posted Part 10 on YouTube.
https://www.youtube.com/watch?v=Z9Bela9bJa8&t=25s
Image20170613_122110_resized by Ben Modified, on Flickr
