Sunday 6-11-17 Our local Solo event in North Charleston
It was nice to sleep in this morning and only have to drive 30 minutes to the venue. Rolled in, unloaded the car off the trailer and bolted on the wing. Then just chill, talk to friends, and look at cool cars until the drivers meeting.
Right at 130 drivers today, broken into 4 run groups. I was work 1, drive 3... awesome get the hot miserable stuff out of the way early and have fun in the heat.
Our group gridded up right at 12:40. Drove the car to the grid and met up with my buddy and co driver Justin. Checked temps and pressures. All 4 145 degrees F, lowered pressures to 8 psi and chalked the tires.
Run 1 - getting a feel for the suspension changes I made and pretty sure this will work. There's an opportunity to fine tune, but the car rotates well, brakes OUTSTANDING, and I can apply power at the apex. Mission accomplished. First run pretty good 26.675 +1
I had to watch the video 3 or 4 times to see where I got a cone. Talked to the corner worker after it was all done and he said I dove over the flat with the rear tire and the tire threw it several feet in the air... guess the tires are sticky.
Co Driver getting a feel for the car got loose after the hairpin and missed a gate for a DNF. Time was 30.085 First time ever sitting in the car... he's going to kick my butt today.
Run 2 - Turn it up a notch. Clean run 26.198. I'll have to see where all the times fall. I know FTD was 24 and small change. HO LEEEE CHIT this is getting fun!!!!
Justin run 2 - Support struts for the wing break welds, wings starts to shimmy, Wing SNAP support struts.
Justin finishes his run and beats me by 0.3 sec.
Run 3 - no wing, tires are sticky PLENTY of power. Decide to see how it's going to handle without a wing, turn it up to 11. I'm putting down a SOLID pass. Rocket through the slalom, hard brake into the hairpin, apex and roll on power, Come out of the hairpin, dodge left and clear the gates, dodge right and don't know what happened SNAP SPIN!!!
Lick my wounds and drive back to grid
Justin run 3. He takes off and it doesn't seem to be putting down power. Not sure what's going on but think I smoked the clutch with my spin. Didn't get his time
Run 4 I pull off from the line, can't put down any power. I think the clutch is done, limp through 29.832
Get back to the grid and tell him it's done. He tells me only the right tire was spinning when I left the line.
Look at the back of the car and....
