...the Hopkinton Center for the Arts "Beatles to Bach 2" faculty concert happened. There ensued a couple weeks of practices and setup. We played great.
After which I was able to return to the Jag Special build, and getting on with fabricating the front upper shock mounts.
Because the G'raj work space is to totally jammed, I spend a lot of time stepping over the front wheels of the Jag Special and looking down at them and their connections to the chassis. During one of those frequent trips, I happened to notice that something looked amiss, like one steering arm was rather closer to the chassis station 2 uprights than the other...
...like this. Driver's side...
..vs. Passenger side.
As Can be imagined, this caused no end of freak out. I swore a lot. I mean, I am fairly sure the post record chronicles the care I'd taken in measurement and alignment and lasers overuse and etc. etc. blah blah blah, but seriously? A half inch difference in longitudinal position of the steering arm tie-rod bosses? seriously?
Of course this caused a three-day session of re-measuring EVERYDAMNTHINGTENMORETIMES, from the Zero Datum to well, everywhere which could possibly have affected that steering arm placement.
As an example, UCA mount cross bar tube to Zero Datum...
...which measured within 1/32 inch end to end. In fact, nothing showed a difference greater than .06, anywhere, so I was somewhat relieved. The logical conclusion is that one steering arm is bent, and I'll remove them both and measure them later.
But, that drama averted, I continued with my top shock mount plans.
With my mockup coilovers in place, I employed the tried and true CAD methodology to create a top shock mount template...
...and made sure it worked on both sides.
I then ordered some 1.5 W x 3.0 H .120 wall rectangle ERW and sat back await it's arrival, during which time it snowed.
And then...
...Et voila ici!
So I used the CAD template to create a dimensioned sketch of the part...
For the Jag Special, the build notebook is getting far more use capturing part fabrication, than did the B-3.
And then, by various means, both roughed out two parts, and hit the 12-pic limit.
And - as I have become so fond of saying - then...
