It is currently January 21, 2019, 12:01 am
Post new topic Reply to topic  [ 171 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 12  Next
PostPosted: November 28, 2017, 10:55 pm
Winding down on the build, Wifey an me gine BIM for 6 weeks, leaving Dec 10. :cheers: :cheers: :cheers:
PostPosted: November 29, 2017, 2:42 pm
Have a nice vacation, Perry.
PostPosted: November 29, 2017, 11:36 pm
Thanks Lonnie, need to warm up these bones.
More work on the frame. Drilled the upper and lower refer plates for plug welding. Tacked up the front hairpin perches, removed plates and final welded perches.
File comment: Hairpin perches welded up
Fitment and alignment, plug welding pics.
File comment: Holes drilled for plug welding
File comment: Refer plate plug welded
Boxed in the upper coilover perches.
File comment: Top coilover perch boxed in
Boxed in refer plates.
File comment: PS refer plate boxed in 1
File comment: DS refer plate boxed in
File comment: PS refer plate boxed in 2
PostPosted: November 30, 2017, 9:36 am
It is good practice when attaching a crossmember to an open channel Side Rail that is carrying high torisonal loads to design the cross member mounting, to S/R, with wider flanges on both the top and bottom channel flanges. I would recomend that you add flanges, top & bottom to the current crossmember, or gussets. If adding flanges, do not weld completely to the inboard S/R flange edge. If using a gusset, then use a fish mounth design, and the welds need to be without any under cut or notches.
Killer project :cheers: Dave W
PostPosted: November 30, 2017, 12:24 pm
davew wrote:
Dave
I can't picture in my mind what you are describing to me. Are you saying the side plate I welded to the channel should have been wider than the channel?
Could you post some example pics?
Thanks
PostPosted: December 1, 2017, 12:15 am
Hey Dave I think I know what you're talking about now. Gusseting a crossmember on the ladder frame to spread the load. Just like the rear cross member on the mouse frame. I will be fabbing cross members for the front of the frame once I get the engine placement set. They will be gusseted. Any channel modifications on the frame will be fish plated and/or gusseted (or refer plated).
File comment: Rear cross member gusset (bottom)
File comment: Rear cross member gusset (top)
So........
There is point in every build where one must cease fabrication, put all the manufactured br@ketz away, sweep the floor, clean the bench, and mock up.
File comment: Engine mock up 1
File comment: Engine mock up 2
File comment: Engine mock up 3
File comment: Engine mock up 4
Placed engine on frame to see fitment obstructions. I say this because I am not building a frame around my donor as the previous 3 builds, I am modifying a frame to accept my donor. Indeed very challenging and forcing me to think way out of my comfort zone, but what else do I have to do.
On another note here is a pic of the diff housing using myself for reference to so the size of it after I've shortened it. Looks like my axles will be ready for pick up on Tuesday. If it appears upside down, I'm standing on my head. Click on pic and it will put me back on my feet.
File comment: Diff size
PostPosted: December 1, 2017, 8:37 am
Hmmm... I didn't think of "standing on your head" when I looked at the pic. (Didn't figger you wuz that athletic...) First thought was "What has he done to that moustache?!?!?"
When are ya heading for the Caribbean? Flying to South FL again? Driving thru Tallahassee this time???
PostPosted: December 1, 2017, 9:06 am
My real concern is that your shock "boxed design" is so ridged that you need to spread out the torsional loads going into the side rail. By adding wider top and bottom crossmember flanges, it will spread out the input loads and prevent a fatigue crack at the side rail mount.
Open channel frames twist a hell of a lot more then the space frames you have been building.
[AND] You get bonus points for your plug weld design brackets :D
Dave W
PostPosted: December 4, 2017, 10:42 pm
Did a bit more frame alterations to be able to fit the eng/trans.
Fabbed up the PS and DS motor mounts. Fabbed the trans mount. Got everything fitted and tacked up.
Some pics.
File comment: Eng in frame front 3/4 view
File comment: Eng in frame rear 3/4 view
File comment: Eng in frame rear view
File comment: Eng in frame front view
File comment: PS motor mount
File comment: DS motor mount
PostPosted: December 8, 2017, 11:23 pm
Bit of progress over the last couple days. Took out the lead pencil, sharpened it, and proceeded to figuring and calculating and scratching. The result was some fabrication of trailing arms, panhard link, and br@cketry. Gussets, fish plates, and refer plates to follow. Geometry is not 100% perfect, but neither is the geometry on my 2007 Dodge Nitro (go over a set of railway tracks on the highway at 50mph and be prepared for some corrective steering). Will need to rework the rear floor to receive the front top trailing arm (otherwise known as restomoding :D ).
Some pics.
File comment: Trailing arms and mounts 1
File comment: Trailing arms and mounts 2
File comment: Trailing arms and mounts 3
File comment: Panhard 1
File comment: Rear end configuration of assembled parts
Will continue constructing end of January when we get back from Barbados.
PostPosted: January 23, 2018, 9:23 pm
Holiday is over, back to retirement work. Picked up my axles, shortened 6inches and re-splined.
PostPosted: January 24, 2018, 11:13 am
nice progress
PostPosted: January 24, 2018, 7:48 pm
Why the bend in the trailing links?
PostPosted: February 5, 2018, 10:48 pm
Nothing scientific really, just wanted them as parallel to level as possible.
A bit of an update, slow going on this build. Installed shortened axles with new brgs and seals. Installed backing plates, brake shoes, e brake cables, and hardware. Installed new drums and test fit tires. Some pics.
File comment: brake hardware installed
File comment: axle and brakes installed
File comment: side view
File comment: rear view
File comment: 3/4 view
File comment: front 3/4 view
Fabbed up LCA mounts and LCA comp rods. Some pics.
File comment: LCA fabbed up with compression rod 2
File comment: LCA fabbed up with compression rod 1
PostPosted: February 8, 2018, 9:52 am
So yesterday I took a brand new chromed R&P and cut 9 1/4" out of it.
File comment: OEM rack dismantled
File comment: Body shortened and welded
File comment: Shaft shortened and R&P put together
Users browsing this forum: Exabot [Bot] and 10 guests
