Didn't mean to imply that you didn't know what you were doing, I'm sure you do, just something that came across my mind. It's very difficult to keep a chassis straight, esp when you fully weld it. Just one of the many challenges of a project like this, but it sounds like you have a plan.
airframefixer wrote:
thanks. I didnt take pictures during the build/welding of the subframes, but the workstand was levelled, and everything was clamped solidly before welding. The suspension pivots all remained flat and square and measured the same before and after welding. For the build table I intend to make 8 posts that will locate the lower suspension pivots in their correct locations above the refernce plane (the bottom of the floor). these will bolt to the work table and hold the subframes up. Then build the chassis inward from the subframes.
However I am perpared to accept a certain degree of warp, Id be crazy if I said it would be made straight/parallel/level without warpage. The idea of making the subframes first was to do most of the welding isolated from the rest of the chassis, so if they warped one way, i could jig them the other way to keep things straight. I have never built a car before so I hope this will work out for me.
l8tr
