It is currently April 16, 2024, 3:31 pm
Post new topic Reply to topic  [ 199 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 14  Next
PostPosted: August 18, 2022, 8:22 pm
So it's been awhile. I've been busy working on the motorhome. Installed an auto gen set start system. Installed a couple of inverters. Installed 3 12V power points in 3 cubby's, so now I can plug in my 12v cooler, pellet grill, and 12v TV outside the motorhome. I can now also watch the big TV and Apple tv inside the motorhome via an inverter. Any time the coach batteries drop below 11V the gen set auto starts, runs for 2 hours to charge the batteries, then shuts down, continuing to monitor the coach battery voltage.
Got 2 dirt bikes running for the grandkids.
BUT! But today I had the chance to introduce the engine/trans to the frame.
I've determined fore/aft position. Engine height places it so that I have 1/2" clearance when I run a straight line from front to back.
BUT! But there is a snafu, the fiberglass hood has a mean 1/2" sag to it. As it sits the hood contacts the oil fill cap. Dropping the engine further down is not an option.
Putting it out there for suggestions to get rid of the sag. I'm thinking of flipping the hood between 2 saw horses, sand bag the middle and apply controlled heat from below.
Looking for any advice, thanks
PostPosted: August 18, 2022, 9:42 pm
Is the sag related to the hold down toggles? It looks like it might be from here. If so, try taking it off and put it in the sunlight upside down for several hours. it might relax. On my hardtop, I added fiberglass reinforcements over a thin wooden piece about 1/2" square around the edges. I think it did its job. You could do the same. You might have to drill a few holes and screw it to something flat (plywood?) when adding the ribs to get the bonnet to lay flat during the process. Then later, repair the screw holes. It might work.
Tha fallback is to form a locost-esqe bonnet out of aluminum. You know how to do that by now. :cheers:
PostPosted: August 19, 2022, 8:44 pm
Or put a slit down the centre of the hood, brace the centreline straight (which will open the slit) and add glass to fill what will be a long skinny lens-shaped opening.
Warren
PostPosted: August 20, 2022, 11:06 am
I'd wedge it up with a 2x4 along the hinge and latched, flood lamp from the top, and check the progress daily.
You may want to lower the drive train a bit to leave clearance for a 3/8 inch support rib for the bonnet.
The rub can be layed up on a sheet of plastic over something flat like glass and the rib formed with a waxed dowel or piece of tubing, then removed once fully cured leaving a flanged U rib to epoxy to the bonnet. Light and stiff.
PostPosted: August 21, 2022, 11:21 am
Thanks for the ideas guys.
I will try flipping the hood and sand bagging the sag with heat, but I don't have much faith in that.
The fiberglass is ~3/16" thick.
Slitting and glassing the gap is most likely what I'll end up doing.
PostPosted: August 22, 2022, 7:40 pm
It takes time, checking, and adjusting to bring it back. It came out of a mold right, then somebody used it as a table for a while.
PostPosted: August 24, 2022, 9:50 am
So I took some time off getting the MH ready for tripping south and built the Gazelle hood an oven.
Put in a 1500W heater, made a jig to measure what's happening.
Waited about 1/2 hour and saw the ruler move 1/16" in the right direction.
I said to myself "self, I am going to grow old waiting for this to happen". Then I had an inspirational thought from the great Tim the Toolman Taylor! What I need is more power!!!
So I upped the btu's a bit.
After 45 minutes and ~188° the hood center moved 9/16" in the right direction. Still have to work the ends a bit, but now I have the clearance I need.
PostPosted: August 24, 2022, 12:40 pm
I like it! I will need to flatten one of my clamshell fenders. Mind if I steel your process?
Thom
PostPosted: August 24, 2022, 2:38 pm
Tim ‘the tool man’ Taylor...my hero! Looks like more power did the trick. Looks great.
Eric
MGiata current build here: https://www.mgexp.com/forum/mga-forum.2 ... n.3898051/
PostPosted: August 25, 2022, 9:20 am
Absolutely Thom, be my guest :cheers:
PostPosted: August 25, 2022, 9:22 am
Eric
Thanks Eric, I see there's a new show with 'Tim' and 'Al' starting up on tv.
PostPosted: August 26, 2022, 9:33 am
No spring back with fiberglass?
Very innovative technique though, Perry.
PostPosted: August 26, 2022, 10:12 pm
Yes there is Lonnie, I waited to see 9/16" when heated to try and get 1/2" as an end result, there's still more tweaking ahead, but it's a work in progress :cheers:
PostPosted: August 26, 2022, 10:27 pm
Bit of an update.
Fabbed up the motor mounts. Couple pics. Will be adding gussets under the horizontal 2"x2" pieces.
Then fabbed up the trans mount br@cket and welded it to the mid section cross member.
Installed the cross member. The frame now supports the eng/trans assembly. With a 6 1/2" ride height the 2"x2" cross member underslung on the frame brings the ride height to 4 1/2" just like my Locosts'. Will be adding a cross member at the front under the oil pan as well, and putting a cross brace connecting each upper front coilover mount.
PostPosted: August 28, 2022, 7:22 pm
Firewall roughed in and fiberglass seat pan frame roughed in.
Fabbed up the the fuel tank cross member and hold down br@cketz
Users browsing this forum: daniel69 and 16 guests
