It is currently April 18, 2024, 11:49 pm
Post new topic Reply to topic  [ 331 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 23  Next
PostPosted: December 3, 2012, 5:06 pm
Jack, yeah I pretty much ignored the claimed concerns about gear noise because there's a whole lot of other noises going on. The sum total will probably make driving with earplugs a good idea.
Part of me is wondering about having two helmets with speakers and mics - I know motorcycles have such setups. With the noise and needed face protection it might be a good idea, other than getting tired of wearing helmets.
Neither of us mentioned your visit to my garage to see the car - or me moving that clamp on the dash and shorting out the battery right in front of you... good times.
PostPosted: December 3, 2012, 7:44 pm
KB58 wrote:
Finally, the first test drive down the street.
http://www.youtube.com/watch?v=KMv6R_qdM3I
Kewl!
jealous ;-)
PostPosted: December 3, 2012, 8:28 pm
Those rear axle shots make it look like it's bent or should I say "not true".
PostPosted: December 3, 2012, 9:37 pm
While I know the axles aren't bent I do wonder about it, whether other cars' axles do the same thing. Halfway tempted to forward that video to the axle maker and see what they say.
[Edit] So I did just that, sent a link to the video to the axle shop. Be interesting what they say...
PostPosted: December 3, 2012, 9:53 pm
Love the video! First time out with the 7/5.0 I said this could kill me! Slow down.
How its the temp with the cooling going down the inside center?
Oh,put the steering wheel on straight ! :mrgreen:
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: December 3, 2012, 10:00 pm
B85 wrote:
... First time out with the 7/5.0 I said this could kill me! Slow down...
Exactly my feelings. Kind of like riding a thoroughbred race horse at a walk and giving her a little tap to see "just what she can do." Yikes, okay, I get it, this thing demands respect!
PostPosted: December 3, 2012, 11:44 pm
Its very motivating watching someones car driving..nice job!
PostPosted: December 4, 2012, 1:26 am
Congratulations! Glad to see it driving and looking forward to seeing it finish becoming fully street worthy/legal. It also looks like it should have no troubles in the acceleration even at partial throttle, let alone whenever you're ready and brave enough to give it everything. :cheers:
PostPosted: December 4, 2012, 10:21 am
Kurt, what rear caster are you running? Camber? Toe? Working on my mid'e's rear upright. Can you adjust all on your car?
Thanks,Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: December 4, 2012, 10:50 am
Rear castor doesn't matter, toe is barely negative, and camber is about 0.7 deg. It's going to take some fussing to find a balance between handling and tire wear.
PostPosted: December 4, 2012, 11:05 am
Thanks Kurt!
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: December 4, 2012, 9:48 pm
I think having a small amount of rear caster is potentially beneficial, especially with the tierods in front of the axle. Everything flexes a little and the caster will add a stabilizing force. TO put it another way....there is no good reason to run negative caster on the rear, and since its impossible to get things perfect, a little positive is a smart/safe idea.
1/2* camber, with 1/2* camber gain per inch bump is probably reasonable. Depends on a lot of things, but typical formula cars have small amounts of suspension travel, pitch and roll, so its probably less important compared to other situations.
PostPosted: December 4, 2012, 10:57 pm
Congrats on the drive! Will we be seeing it tearing up the track at the Q sometime soon?
What are you planning on registering it as? I believe if it doesn't look like a period car, it can be registered as a 1960 - is that right?
Martin
PostPosted: December 7, 2012, 8:10 pm
I'm also wondering how it will be registered.
Quick question Kurt, how close is your fuel cell to the rear firewall and the engine? I'm scratching my plan on building a from scratch car with the 4g63 because I'm planning on building a car with a modified midlana plan once you start selling the book. I'm slightly worried about how close the turbo will be to the fuel cell in my setup though.
My build -> viewtopic.php?t=15585
PostPosted: December 7, 2012, 9:09 pm
I'm in California so it goes under the SB100 rules, meaning that it'll either be registered as a "Lotus Seven" (no kidding) or as a generic 1961 car. People bitch and moan about CA but honestly, it's one of the easiest states to register a one-off car in.
The fuel tank/cell is just forward of the main roll hoop, and behind the seats. Because of that you can easily add a heat shield. A double layer of stainless separated by about 1/8" is a VERY effective heat shield. Plus, the turbo will be a ways above and behind the tank, probably at least 12" away.
