It is currently February 24, 2020, 4:31 am
Post new topic Reply to topic  [ 308 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21
PostPosted: February 26, 2017, 10:29 am
The metal heater shroud didn't workout as planned. It was far to heavy and oversized I made a plastic cover with a 3in outlet. It fits in the passenger side footwell and doesn't look bad either. Needs some ducting from the outside of the car. Fan maybe overkill lol.
Evo
My vq30 middy build http://www.locostusa.com/forums/viewtopic.php?f=36&t=4082
PostPosted: February 26, 2017, 2:17 pm
Here it is in its mounted position. I've been working on this for a long while and overall it meets all of my requirements. Thin and cheap. I was happy to build it out of parts I already have.
Evo
PostPosted: February 26, 2017, 2:32 pm
As a plumber I recognize that outlet, I will let you tell everyone what it is.
PostPosted: February 26, 2017, 3:02 pm
Hint: it's intended for a room in which you can sit and ponder.
PostPosted: February 26, 2017, 4:07 pm
You found my "office" of inspiration... :mrgreen:
Evo
PostPosted: July 3, 2017, 4:36 pm
Lots of little updates. The car now has headlights and turn signals. Turn signals are a dual filament from a harley and headlights are 5 3/4 jobbers. I'm working on reducing the rear shock mounts as they weren't adjusted for droop correctly, no pictures yet. Next I'm moving the battery to the engine bay to make room for my new heater. I brought a zirgo golbi heater from newegg for $65 with shipping. It's very compact and will live where the battery was mounted under the scuttle. Also mounted the horns and added an x brace to the front of the chassis.Progress has been slow but I haven't given up. Still get an hour or two a week to work on it.
Also added a clutch pedal which was made from a modified s2000 assembly.
Headlights
Clutch pedal
Upper fuel tank firewall door.
Zirgo heater
Evo
PostPosted: July 3, 2017, 7:48 pm
Another headlight pic. Lower bracket was a made from 3 pieces. Speed holes for lightness.
Front brace and horns.
Upper firewall.
Fuel filler access door.
Zirgo heater side.
PostPosted: June 29, 2019, 11:17 pm
Finished reading from the beginning. Any more updates?
David
