Thanks to each of you on Locost Builders.UK and Locost USA.com who offered suggestions for evaluating and correcting the overheating problem on the Mabaan build.
I’m back from a long weekend trip to Iowa and ready to attack the issue armed with the suggestions made by you all. I’m sure that through one or more adjustments drawn from those offered the issue can be solved.
To help organize my plan of attack I thought I’d list the suggestions here in one place for quick review. Perhaps in the future others may run into a similar situation and find the paraphrased information/suggestions provided here helpful as well.
AIR FLOW:
KB58, carguy123, Kartracer47 and olrowdy-01 offered suggestions for analyzing and increasing the effectiveness of airflow through the ducts and radiator cores including wool-tuft studies and cautions associated with rad angle, relative intake/exit dimensions, air direction diffusers as well as concerns about the debris screens.
Olrowdy-01 listed two suggestions for information and review:
http://www.ch601.org/resources/cooling_systems2.htm and viewtopic.php?f=23&t=4406&start=75
I’ll be conducting airflow circulation studies. Thanks!
ENGINE BUILD[u]:
KB58 alerted me to the fact that if the engine is built “too tight” an overheating issue may occur.
Based upon the race engine experience of the builder I don’t see this as being a factor but thanks for the alert.
[u]RADIATOR BLEED TUBES:
Kartracer47 pointed out the need for bleed tubes from the rads to the higher components of the cooling system to eliminate the possibility of trapped steam pockets forming in the lower areas of the rads.
Currently I have bleed vales on each rad but neither of them is connected back to the surge tank. I installed them to drain-off trapped air during the initial filling of the cooling system. An open valve connection will be one of the first retrofits made. Thanks!
INNATE CHARACTERISTIC OF LT1 ENGINES AND LEVEL INSTALLATION: John Hennessy identified a potential problem when this engine is mounted in a level orientation (as is the case here) causing trapped air (steam) to form in the rear portion of the heads.
John’s suggestion of tapping into the rear section of the heads with a pressure release pipe or tube connected to the thermostat housing will be done. Thanks!
COOLANT FLOW:
Oldejack suggested and MYTF seconded his suggestion of running the rads in series rather than in parallel as they are now. He also suggested in-line flow restrictors to control time and velocity of the fluid as it passes different areas in the system guarding against possible unequal usage between the two rads. Doug68 provided two interesting and extensive reference sites dealing with coolant flow, rad and pipe differences and a convenient list of basic rules for reducing heat in performance engines.
http://www.gt40s.com/forum/gt40-tech-en ... tions.html
and
http://www.arrowheadradiator.com/14_rul ... obiles.htm
Gakes pointed out possible fluid flow issues caused by different configurations of hose connectors “T-type” vs. “Y-type” connectors and seconded the series arrangement.
Fred W B simply agreed with Series over parallel plumbing.
Hughpinder agreed with the parallel plumbing and suggested running W/O a thermostat in addition to suggesting the possible need for an auxiliary water pump to increase flow.
Interestingly, I debated with myself, series over parallel plumbing, and it seems that true to my history of choosing the wrong choice in a 50/50 proposition, went with parallel. Now with the preponderance of you believing that series would be better, it will be changed to series. Thanks!
CHECKS TO BE MADE: Ivan suggested checking temp differences between the rads to determine if flow is an issue.
Thanks to all who offered critique and possible solutions. Again, I’m confident that through one, or more likely multiple corrections, drawn from your experiences this problem will be alleviated on the Mabaan.
Thanks again,
Dick Bear
