It is currently July 9, 2020, 10:50 am
Post new topic Reply to topic  [ 856 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 58  Next
 Post subject: Re: Mako Exo style car
PostPosted: March 24, 2011, 2:58 pm
cheapracer wrote:
b-t wrote:
Stock fan.
Thank you.
Don't know if this helps what you are doing right now ..
http://www.ephotomotion.com/914engine/page37.html
It's funny that I just read that page of info less than a week ago. I have to go get some of those 12mm across the flats nuts for sure. The 13MM sockets don't like the space that they have to work with. The exhaust guy said getting an attachment to the stub pipes would be easy, but turning up to our mounted mufflers will be difficult. I was thinking it was just the opposite, but I'm no exhaust fabricator, so I will just see what he does I guess.
8)
BT
PostPosted: March 24, 2011, 9:30 pm
I tried to get him to go for the 911 style, but then I saw the prices :shock:
PooK
dpook317@att.net
PostPosted: March 24, 2011, 9:39 pm
Back on the "S" checking axle alignments...so far so good but we will have to switch to inboard suspension.
BTW I'm thinking we should leave the output, call it a PTO and have the worlds fastest lawnmower?
PooK
dpook317@att.net
PostPosted: March 25, 2011, 1:20 am
PooK
I was hoping that was going to be the answer too, very cool (pun intended!).
PostPosted: March 25, 2011, 9:27 am
With some turf tires and the PTO you could make one fast finish mower with that car. :mrgreen:
Minibuggy build to see if I could hack a car build: http://www.minibuggy.net/forum/ar51-buggy-group/16171-ar51-build-ky.html
Finished product: http://www.fawbush.org/images/2012_8_19_buggy/2012_8_19_first_drive_6.JPG
PostPosted: March 25, 2011, 12:34 pm
PooK
Pusher prop :mrgreen:
PostPosted: March 28, 2011, 9:13 am
Ground effects car...seems obvious to me!
PostPosted: March 28, 2011, 7:20 pm
Here is the headers installed. The total cost of the exhaust system was around $550 ($450 for the custom headers, and about $100 for the dual silencers)...
I love the look of this setup. The collector is not ideal, but there is only about a 20% overlap of the exhaust pulses by my best guess.
BT
PostPosted: April 4, 2011, 1:04 pm
Danny tells me that I need to post up some pictures, so here is the latest:
File comment: prepping the headlight buckets for paint.
File comment: Some of the fenders ready for primer...
File comment: Testing the resistance of the fuel sender. The digital instrument cluster wants 100 ohms empty, this is close enough.
File comment: Split collar to prevent the sway bar from changing location (typical of four).
File comment: Headlights, fuel sender, and horns installed, just need a little wiring to finish up....
File comment: Actually, there is a lot of wires, I am hoping to have the wiring done in about 10 days.
BT
PostPosted: April 4, 2011, 5:06 pm
The windshield came back from the glass shop today. It uses some molding specifically made to conform to a round tube frame. I think it looks nice.
BT
File comment: Here is one showing the overall windshield frame on the car.
File comment: A close up showing the molding over the round tube frame.
File comment: the PPG DOT AS-1 stamp...
PostPosted: April 4, 2011, 8:19 pm
too bad they made the corner seam look like edit(poop)
PostPosted: April 4, 2011, 8:28 pm
Considering what I have seen with other round tube windshield designs, I think it looks awesome. If you are looking with your nose 8" from the corner you can see a less than perfect seam. If you look from 5 feet (like the top picture) it looks great! I searched this site for an improved product, but could not find any. Most everyone has exposed fasteners around the edge and a basically unfinished look. Maybe you could point me to the better examples of curved round tube frame designs that are finished. Thanks in advance!
BT
PostPosted: April 4, 2011, 8:37 pm
sorry, maybe im being picky... when i am making moldings like that, i make sure they look seamless. thats all, i do automotive glass work for a living
PostPosted: April 5, 2011, 10:04 am
Any chance I could get some close up picks of the front cycle wing mounts, and how you have them mounted.
Thanks so much...
PostPosted: April 5, 2011, 11:02 am
We use two mounts per fender. One of them goes onto a 1.25" square tab that replaces the washer behind one of the caliper bolts, the other attaches to a 1.25"x3" or so tab that is held with two 3/8" x 1" bolts IIRC. There is a built in space on the Solstice hubs that is used to hold a little tool used during an alignment. We tapped the holes to accept the bolts we used. I will try to get a pic of them a little later. We use the same bent 3/8" rod for all four corners, it just mounts to the tabs differently, and the front bar that mounts to the larger tab has a bend in the perpendicular axis to avoid interference with the steering rod. The rods start as 27" pieces for the long ones, and 21" for the short ones IIRC. It is a pretty simple system, and one you could probably do on just about any aluminum upright that you could drill and tap.
BT
